Old 12-07-2009, 06:36 PM   #1
XnTroubleX
XnTroubleX's Avatar
XnTroubleX is an unknown quantity at this point
Exclamation Turbo Guidance
Ok yall, Ive got a 90 240 with a sr swap, Im in the process of upgrading my manifold to the I.S.I.S cast top mount, and the GT 3071R .63. Im ordering my turbo from ATP, externally wastegated, T3, 4 bolt exhaust discharge. Well heres my problem. since im switching from bottom mount to top mount and I was going to choose the 4 bolt exhaust to Vband.I can find the 4 bolt-V-band flange. but I can not find a elbow to go from the flange to my down pipe. I just switched to cars from bikes so Im pretty new to all of this. I have researched alot, so no need for flaming, Im pretty sure this set up is common and some company has to have the elbows sitting on a shelf waiting for me to buy it but I cant find it. Thanks for the imput guys and girls!
XnTroubleX is offline   Reply With Quote
Old 12-07-2009, 06:39 PM   #2
ballinnmiami240sx
ballinnmiami240sx's Avatar
ballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura about
You are not going to find something that fits. you'll have to fab up your own elbow.
1994 FD3S Drift // 945garage // sumospeed.com
ballinnmiami240sx is offline   Reply With Quote
Old 12-07-2009, 06:43 PM   #3
XnTroubleX
XnTroubleX's Avatar
Well WTF!! I dont have a welding machine!!
Old 12-07-2009, 06:47 PM   #4
Max_PSi
Max_PSi's Avatar
Max_PSi will become famous soon enoughMax_PSi will become famous soon enoughMax_PSi will become famous soon enough
Looks like your gonna have to find someone with one then.
Have someone fab up the elbow and then weld it onto the flange.
Max_PSi is offline   Reply With Quote
Old 12-07-2009, 06:55 PM   #5
XnTroubleX
XnTroubleX's Avatar
Is their an alternative route I can go to avoid having to fabricate something?
Old 12-07-2009, 07:22 PM   #6
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
what wrong with having someone fab you one? Some shop do a damn good job at it.
bl3ujay07 is offline   Reply With Quote
Old 12-07-2009, 07:36 PM   #7
XnTroubleX
XnTroubleX's Avatar
Well I was looking and I think I could get a Flex bellow add a 2 extension on the bottom and have the 3 bolt cat flange welded to that. then buy a already bent 45 degree joint put that on top of the flex, and have the appropraite angle cut at the top and weld that to a V-band flange and badda bing badda boom, ??? IDK maybe that was just a crazy idea?
Old 12-07-2009, 07:38 PM   #8
Nezahualcoyotl
Nezahualcoyotl's Avatar
Nezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-known
an alternative would go back to bottom mount
lol well as stated above fabing the elbow would be your only choice unless you by chance find a used one for sale that fits. visit your local exhaust shop or the like and ask them how much it would cost to do something like this
good luck
edit: the way you described it you would cut existing parts and welding them together? its plausible but it would be easier to have someone fab a full piece out of scratch. it wouldn't be all that expensive i believe.
Nezahualcoyotl is offline   Reply With Quote
Old 12-07-2009, 07:41 PM   #9
XnTroubleX
XnTroubleX's Avatar
Word!!! Bottom mount = no creativity!! Im going to figure it out. I think my previously posted idea would work.
Old 12-07-2009, 09:05 PM   #10
slider2828
slider2828's Avatar
T3 frames on bottom mounts suck ass... Don't bother.. No there are no bolt on kits, just have someone fab it up...
Turn and Burn!
