Old 12-09-2009, 06:52 PM   #1
nrmskate
nrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura about
SOHC to DOHC Questions (Swap is complete)
Okay, so I finished up my sohc to dohc swap the other day and it fired up first try, but I shut it off after a few seconds seeing that I don't have the ps/waterpump belt on.
The reason I don't have it on yet is:
A) I only have the SOHC pully, it fits on the DOHC but has 3 ribs instead of 2, and I don't know if the SOHC and DOHC waterpump pullys are the same diameter, if they were the same diameter, would the ribs really even matter?
B) I don't have the entire PS setup connected because im missing a line and don't want to run a dry PS pump, because frankly, I don't want to wear the bearing in it dry
So, my questions are, can I use the SOHC waterpump pulley on KA24DE?
and will the PS line that runs along the engine crossmember work for DOHC setup, or do I have to use the DOHC line, the rest of the lines are DOHC, the only line remaining from the SOHC is the one running along the x-member. I would go look and compare the too, but, it's -3 degrees outside.
Thanks.
nrmskate is offline   Reply With Quote
