Old 12-12-2009, 12:12 PM   #1
harsh tymes s13
harsh tymes s13's Avatar
harsh tymes s13 is an unknown quantity at this point
Post wheel Offset help please?!
I have a 1990 240sx with 5 lug conversion. I am going to run 18x9.5 wheels in the rear. I don't want the wheels to stick out past the fender. What offset should I run. I was thinking 15m for the rear. The front will be 30m offset. All of my fenders are rolled. I'm going to use a 245/45r18 for the rear tires as well. Accurate experienced advice is appreciated.
harsh tymes s13 is offline   Reply With Quote
Old 12-12-2009, 12:48 PM   #2
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
http://zilvia.net/f/chat/129865-whee...tch-flush.html
There's 252 pages of information from experienced people in there.
Next time search before making a new thread.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 12-12-2009, 01:07 PM   #3
h815 240sx
h815 240sx is an unknown quantity at this point
r +12
f +22
h815 240sx is offline   Reply With Quote
Old 12-12-2009, 01:11 PM   #4
sickstatus
sickstatus's Avatar
sickstatus is an unknown quantity at this point
Send a message via AIM to sickstatus
+1000 in the front.
+1500 in the rear.
straights are for fast cars, corners are for fast drivers.
sickstatus is offline   Reply With Quote
Old 12-12-2009, 03:10 PM   #5
JurisMyDiction
JurisMyDiction is an unknown quantity at this point
to be honest. i've looked through about 50 pages of the thread so far and can't seem to get an answer to my question... there whould be an "ask about offset here" thread.
i for instance am probably getting wheels that are 8 in wide up front and 10 in the back, either that or 10 all the way around. i hve no clue what offset to get and haven't found anyone in that thread that's running that size in the front so compare offsets. i guess gotta keep looking.
JurisMyDiction is offline   Reply With Quote
Old 12-12-2009, 03:16 PM   #6
Slammed180
That thread isn't to find your exact set-up.
Look for key traits. Stock fenders, either rolled or pulled. Overfenders, 30mm, 50mm, 70mm. Tire size, either stretched or meaty. And then look at their wheel size. Use an offset calculator (Wheel Offset Calculator), and compare what you want to run with what they're running.
It's not that hard really.
Blow me, bitches.
Old 12-12-2009, 03:22 PM   #7
Slammed180
and because I'm feeling nice, there's two example of the set-up you're wanting to run on this page.
http://zilvia.net/f/chat/129865-whee...ml#post3073889
Blow me, bitches.
Old 12-12-2009, 08:54 PM   #8
harsh tymes s13
appreciate the calculator. also if i have searched and haven't found my exact answer. i will post another thread. either answer the question or keep moving. its not killing you if the thread is here. well guess it did, cause you just had to say something. thanks for being nice.
Old 12-13-2009, 08:59 AM   #9
JurisMyDiction
thank you sir, that actually helped perfectly.
