Old 05-26-2003, 10:02 PM   #1
skmcbride
skmcbride is an unknown quantity at this point
4 to 5 lug adapters
Anybody ever seen or used these and are they worth it, pros/cons?
http://www.speedalliance.com/images_...b_adapters.jpg
Thanks, Keith
skmcbride is offline   Reply With Quote
Old 05-26-2003, 10:25 PM   #2
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
It is basically a (fairly wide) spacer. You will need to take it into account in the offset of whatever wheels you are going to put on them. Given how simple they are, the only drawback I see is additional rotating mass, any other comments?
Rowsdower saves us and saves all the world!
misnomer is offline   Reply With Quote
Old 05-26-2003, 10:27 PM   #3
adey
adey's Avatar
adey is an unknown quantity at this point
I don't see how they connect to the stock 4 lugs/hub. lugs are splined going through the hub, so you can't screw them into the back like that... what am I missing?
edit: Wait a second, so you have to unbolt/bolt the thing together yourself? So first you torque down the 4-lug side to the hub, then you bolt the 5-lug side onto the 4-lug side, then mount the wheel and torque it down? ... wow. Long process... if I'm right that is. I guess it's hard to do any other way, but... still.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 05-26-2003, 10:31 PM   #4
misnomer
misnomer's Avatar
This is speculation because it's been a while since I last took off my rotors, but it looks like there are two peices to this thing. The front goes over the lugs, the back is attached to the other side of the hub using those hex bolts? Maybe? Possibly?
Old 05-26-2003, 11:12 PM   #5
Tekryder
Tekryder's Avatar
Tekryder is an unknown quantity at this point
I would rock em. They look decent. It should be good for me since Im planin to go Widebody anyways.
Shift_Played Out
Tekryder is offline   Reply With Quote
Old 05-27-2003, 09:30 AM   #6
AKADriver
AKADriver's Avatar
Looks like it to me. That's about the only way they could make a 4-to-5 lug adapter safely. Not really a problem, since you only need to remove the adapter when you replace rotors or otherwise need to disassemble the spindle.
Old 05-27-2003, 09:40 AM   #7
Dousan_PG
Dousan_PG's Avatar
i wouldnt use those. but that's just me. i dont feel safe w/ a converter. im sure it is but...i recall someone's breaking due to either not checking or poor quality
just get the real 5 lug conversion and be done. if you only have 2 wheels you like go w/ the dope 20 lug (4 lug front 5 lug rear or vise versa) conversion best of both worlds
Aaron
Pink GodziRa
Old 05-27-2003, 10:41 AM   #8
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
how much are they?
TheSparo is offline   Reply With Quote
Old 05-27-2003, 02:56 PM   #9
skmcbride
I think they are around $180.00. I like the idea of the added offset and the abundance of 5 lug wheel choices. I can't quite make out how they attach to the existing 4 lug given the thickness. Even if it is 2 pieces the inner section would need to carry the 4 lug thread and a counter sunk lug nut before outer portion is attached. What am I missing?
Thanks, Keith
Old 05-27-2003, 03:35 PM   #10
mrmephistopheles
mrmephistopheles's Avatar
Wayne from Phase2 had that happen to him.
Originally Posted by PHLIP
Old 05-30-2003, 01:56 PM   #11
YellwMonky
YellwMonky's Avatar
YellwMonky is an unknown quantity at this point
I just found out that those converters space the wheels out by 45mm. If I were to get these converters, i would put on the s14 stock SE rims. If I used these converters, would even the stock rims stick out from the fender? Or would they be flush?
s13 92 White 240sx SE Coupe
YellwMonky is offline   Reply With Quote
Old 05-30-2003, 01:59 PM   #12
Dousan_PG
Dousan_PG's Avatar
stick out!!
stock is +40
you'd make the offset -5
yikes!
Aaron
Pink GodziRa
