Old 12-19-2009, 02:46 AM   #1
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
06 350Z front brakes
Got a set of huge 350Z front brakes.
Rotors are 320mmx28mm.
Rotors are in good condition, no grooves and such.
Pads have lots of life left.
The mounting holes on the spindles need to be opened up to 14mm.
SS braided lines included.
You'll need at least a 17in wheel.
Setup consist of:
Calipers
Rotors
Lines
Modded S13 Spindles(no hubs)
$220
Shipping will be pricey due to the weight.
MrMcgarrett is offline
Old 12-19-2009, 09:35 AM   #2
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
Whats modded on the spindle?
SDS13COUPE is offline
Old 12-19-2009, 09:39 AM   #3
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
the bolt holes have to be drilled to a larger size. i forgot how big. i had to do this for mine
Marcus is offline
Old 12-19-2009, 10:20 AM   #4
rb25crazy
rb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of light
if u mod the spindle the 5 lug hub works too?
rb25crazy is offline
Old 12-19-2009, 11:29 AM   #5
Def
Damn, can you fools not read?!?!
You drill the caliper mounting holes on the spindle up to 14 mm(up from the S13/S14 stock 14 mm).
S13 Hatch - Goes around tracks quickly
DEFSPORT
Def is offline
Old 12-19-2009, 12:16 PM   #6
MrMcgarrett
See below post lol
Old 12-19-2009, 12:21 PM   #7
MrMcgarrett
The mounting holes were drilled to 9/16in(14.3mm)
Little bigger then they need to be but I couldn't find a 14mm drill bit.
The hubs were made for the S13 spindle.
Old 12-19-2009, 09:22 PM   #8
nochain
nochain is an unknown quantity at this point
FREE BUMP haha
I put a set on my z31 worked hella good wish I still had them I would buy but I need to find a 5 lug setup first that is not retarded expensive
nochain is offline
Old 12-20-2009, 07:19 PM   #9
MrMcgarrett
Last time to the top.
