Old 05-30-2003, 02:36 AM   #1
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
SR howto- gaskets manifold and turbo
I need to replace my exhaust manifold gasket, and the gasket that goes between my exhaust manifold and the turbo. Well if i can get away with just the exhaust manifold/turbo gasket it'll be alright, but i've been told u need to take off the manifold to get the other gasket ?
Can anyone give me any step by steps?
speeddreamz is offline   Reply With Quote
Old 05-30-2003, 03:33 AM   #2
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
There's no step by step process. Just unbolt stuff. I have done it three times now and the nuts holding the turbo to the manifold will give you some serious issues. Take your time and keep your patience and you will get them.
Easiest way I have found:
-loosen nuts holding manifold (don't remove)
-unbolt turbo from manifold and remove
-remove manifold from block
Reason I do it in that order is you can shimmy the manifold around to make it easier to get the turbo off the studs
Have fun... muahahahahah
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
Old 05-30-2003, 07:14 AM   #3
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
mm things that need to be unbolted... hotpipe, intake pipe, and both the metal pipes that they connect to on the turbo (makes it easier to get out) unbolt your downpipe. get a drain pan. unbolt two banjo bolts (dont lose the clips) one is oil one is coolant. (remeber to refill both) there is a hose underneath the turbo and one that goes behind the block. remove those. unbolt manifold and wrestle it out. not a fun job. did it two weeks ago. next time a bigger turbos going on that sucker. reinstall in reverse order.. double check ALL THE HOSES. I forgot the oil return line on mine. started the car and dumped a quart and a half of oil. had to jack the car back up at 4a.m. in the rain and crawl under the car in my club clothes so I could get home.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 05-30-2003, 01:24 PM   #4
nrcooled
nrcooled's Avatar
I did leave out the fact that I disconect the hot pipe but damn i can't belive you do all that to get to the gasket. If you just take out the manifold and leave the turbo in place you will save alot of time and trouble when putting everything back together. Not to mention you won't have to get under the car in club clothes. Like I said in my first post, I unfortunately have had to do this three times. Due to tracking my car and burning the base gasket up and have never run into a problem the way that I have done it
Old 05-30-2003, 02:15 PM   #5
Steeles
Steeles's Avatar
dude I tried that the first time and could NOT get to the bolts on the engine side of the turbo to get them off. i even thought about slitting the gasket and forcing it over the bolts this last time... but one of the nuts had worked itself off and I needed to inspect the turbo anyway. Second time in 3 months I've done that but believe me I'll try even harder next time to not have to go through all that. (hoping there wont BE a next time though)
Old 05-30-2003, 03:00 PM   #6
nrcooled
nrcooled's Avatar
w3rd! It is a PITA to get it off and on. I just use a 13mm wrench and a lot of patience. Usually takes about 3-4hrs to get the job completely done. The result is worth the effort...quieter exhaust, more immediate boost, no exhaust smoke in the car.
Old 05-30-2003, 03:13 PM   #7
Steeles
Steeles's Avatar
hehe well next time the frigginthing comes off I'm pulling the engine. I gotta do front and rear main seals, I've got a bigger turbo on its way so might as well. try and get my injectors by then and cams so I can do it all at once. and hopefully not worry about any of that crap for a long long time. then i'll rest and enjoy the car.
