new fuel system upgrade questions?
i have a greddy rail and rc750's. -6AN fitting on the rail. what would be the simplest soultion to running the fuel lines? install the right fitting onto the hard lines and add ss lines and boom im done? the 750's are peek and holds,
also what fuel pressure reg. should i pick up? ![]() ![]() |
Run new lines from back of the car forward. With that size injector it sounds like you are going for 400+hp or run e85 or something like it so you will need the volume of larger lines. How much power you plan to make? less than 500hp -6 feed line should be good enough above that -8 should be used.
Aeromotive makes nice fuel pressure regulators, they are the only ones I've used so that is all I can suggest. |
Thats just missinformation.
I have dynoed over 530HP, with 850cc injectors, pump fuel, and stock fuel lines and rail, wich I.D. is much smaller than AN6 I.D. I would run 6AN but not bigger, especcialy for any power you can ever make on those injectors - and thats only if you insist on going to AN fittings. Otherwise in your case, i would remain stock. Runing bigger lines, just means your pump needs to work much harder to maintain fuel pressure. |
It is not misinformation it is what is ideal for setting up a proper fuel system. And I have no idea how you made 530hp to the wheels with 850cc injectors on a 4 cylinder The duty cycle must be well into the 100's,or you were spraying. What fuel pump were you using? and If you are running the 850's at full capacity your trying to pull almost 2.5 times more fuel than the stock system is designed for I wouldn't trust my motor with those lines. If the o.p. is staying below 400hp then IMO stock lines are fine above that IMO lines should be upgraded.
#6 |
keep the 750s if your thinking about 350, better than maxing out 550s or running them close to a high load
#7 |
![]() Join Date: Feb 2008
![]() Feedback Score: 6 reviews
^^^Agreed. 550's are not enough. I had the sard 550cc that were rated at 320 but were maxed out with my gt2871r at only 1.1 bar. i would stick with the 750's if i were you.
#10 |
I am peaking at 80% duty at 7300 RPM. Using pump fuel, AFR's around 11.8 .
The power is at the HUBS - 530HP, so meaby you are a bit confused with ATW power. Still - I have the graphs to prove it - they have been posted here, several times. Do a search on my user name. Saying that 6AN lines "should" be good enough for 500hp, IS missinformation, or just plain wrong - take your peak. Stock line is much smaller I.D. then a -6 line, and it works fine. Anyway.....whatever. |
