Old 06-08-2003, 07:49 AM   #1
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
Washers for Wheel Spacers
I've always wondered if you can just put bolt washers behind your wheels and do the same as a spacer? I know this idea is ghetto, but whats the difference as long as it pushes your wheel out.
RedlineRacer is offline   Reply With Quote
Old 06-08-2003, 09:18 AM   #2
PooPoo240
PooPoo240 will become famous soon enoughPooPoo240 will become famous soon enoughPooPoo240 will become famous soon enoughPooPoo240 will become famous soon enough
hehehe...
no real difference... I just completed the 300zx brake upgrade, and until I recieve my SSR's I have 3 washers on every bolt on some velox 17's...temporary. just make sure they're all the same thickness.
PooPoo240 is offline   Reply With Quote
Old 06-08-2003, 03:40 PM   #3
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
2 things come to mind
1. structural integrity...the spacer will be a ring w/ holes for the studs to come through....being a nice strong piece w/ a nice seat for the wheel/hub to come together as it should, while the washers will have gaps being less sturdy
2. structural integrity (part 2)...unless the washers are nice and strong, i can imagine that eventually one may bend/collapse sending you and your car into hopless oblivion and well, debt after you try and repair the suspension you wreaked havoc on...
if ur gonna make it permanent better spring a couple hundred on the real deal...
optauto.com they have nice spacers that come w/ all the hardware...i plan on gettin 10/15mm spacers from them cuz i have some high offset wheels too :-\, previous owner's mistake, not mine
Ian is offline   Reply With Quote
Old 06-08-2003, 03:42 PM   #4
nguyenk2003
nguyenk2003's Avatar
nguyenk2003 is an unknown quantity at this point
Send a message via AIM to nguyenk2003
Its al right I guess, But if you gonna do any Hard rving, I wouldnt. IF you do Use Washers as Spacers and do Hard Driving, the Space Between the Lugs have more stress o nthe rim... I guess.. But I duno, I dont know, I was thinkgin abotu it, but then I rather spen 50$ mroe to be safer than sorry.
nguyenk2003 is offline   Reply With Quote
Old 06-08-2003, 06:33 PM   #5
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
No, No, Nooooooooo!!!!
Bad idea!
Think about it - Without any spacer, all the force on your wheel is being spread over the surface area of the back of the wheel, which bascially matches the hub. The lugs do nothing but hold the wheel onto the hub securely - No up and down forces applied to them.
You add washers, and the studs are forced to take the up/down load of the wheel, which they were not designed to do. They will shear off eventually.
Please do not drive like that and risk losing your whole car over something as cheap as a $95 set of hubcentric spacers.
orion::S14 is offline   Reply With Quote
Old 06-08-2003, 07:37 PM   #6
theronin
theronin's Avatar
theronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfection
Send a message via AIM to theronin
i agree with orion... just get some real spacers and save yourself a potential disaster... here ill even give you the link to make it easy! Click Me!
Originally Posted by HalveBlue View Post
That first picture is totally bad ass.
It just screams, "Hey, I'm a fucking Christmas Tree. What are you gonna do about it?"
theronin is offline   Reply With Quote
Old 06-09-2003, 07:28 PM   #7
THX1138
THX1138 is an unknown quantity at this point
Or you can click here for spacers that are less than $95, but still beat the crap out of washers.
Just scroll down a bit, 'cause Don's still the man.
THX1138 is offline   Reply With Quote
