Camber correction??
If i am just going to lower it like 1.3"-1.5" would i need to correct the negative camber, or could i get away with it as is? Dont want to burn up tires really fast, so ill fix if it needs to be. Advice/pics? Any help appreciated. thanks.
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
-1.5 WONT kill tires
that's a MYTH bad toe WILL thats why after you lower cars you GET AN ALIGNMENT, primarily to fix that toe which will just murder tires now camber ipersonally say beyond -3 then you'll REALLY notice wear many of my friends use -2 or so daily and no unusual or obscene camber wear. -2.5 is ok too, but i say -3 or more, it will wear much faster, especially if you go on the track ![]() UCanTry: pillow ball mounts no, rear is pillow ball and you CANNOT adjust rear camber via them. fonts need camber plates rear needs upper arms stock has a eccentric bolt, i THINK there are aftermarket ones not sure. but rear upper arms will get it back to 0 degrees or up to -10 or more im sure hahaha.. |
it will kill. i have -1.8 degree camber on my pass. side rear wheel... and its killing it. fast too.
my toe wasnt off taht bad (i lowered my s14 1.5") but i got that fixed. s14s have rear camber adjustment bolts, i know that... so you can fix it. but if the front is off, your screwed, like me. |
