Old 01-30-2010, 03:37 AM   #1
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
300zx caliper BIG rotor upgrade kit!
I'm selling a z32 rotor upgrade kit. Installs a !!!324mm!!! rotor on your z32 brake set-up. These components are of the highest quality, not china made junk. !you'll be stopping like a mad man.
-Rotors are z33 brembo ed. Centric; Drilled and chamfered, balanced and zinc coated *NEW
-Real JSK caliper brackets helicoiled and hardened steel hardware. (not that ebay junk )
Direct bolt on upgrade if you have z32 calipers, get a killer 12.75" rotor
Increasing brake power by moving the caliper farther out, delivering more torque to the rotor for optimal braking with the z32 caliper, and a larger rotor can take more heat, less susceptible to fade.
$300.00 for everything shipped!
*STILL FOR SALE! FIRST COME FIRST SERVE!!
Chrischeezer is offline
