Old 02-03-2010, 07:44 PM   #1
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
sr20 check list
ok so i have been doing ALOT of research, im just gonna clarify this with you guys
im buying an sr20det motor set on ebay, they have really good deals, and its just companies posting on ebay, so im not too worried.. comes with a warranty and all
this isn't the exact motor im getting, but this is pretty much the package im gonna get
89-93 NISSAN SILVIA S13 240SX BLACKTOP ENGINE SR20DET : eBay Motors (item 230429193079 end time Feb-04-10 14:05:23 PST)
its comes with : MANUAL RWD TRANSMISSION, WIRING HARNESS, ECU, MAF SENSOR, & IGNITOR
im doing a SOHC to DOHC swap, so
ALL I WOULD NEED is to
-get harness re-wired for usdm
-DOHC ps lines and resovoir
-Sr20 Radiator
-Radiator Hoses
-heater hoses?? would i need vacc hoses too?
-DOHC CLUSTER
-255 Fuel Pump
-Front mount intercooler
-BOV
-downpipe
-3" catback
-test pipe, or may just keep my cat
if i am missing anything from my list, could you guys please let me know? thanks
Options13 is offline   Reply With Quote
Old 02-03-2010, 07:54 PM   #2
theslows13
theslows13 will become famous soon enoughtheslows13 will become famous soon enoughtheslows13 will become famous soon enough
since you posted nicely, ill respond nicely.
list sounds good as a starting point. youll ALWAYS find small things you forgot, no matter how much you plan ahead.
throw a new clutch on it before it goes in.
new vacuum lines are a good choice, as are fuel.
theslows13 is offline   Reply With Quote
Old 02-03-2010, 08:11 PM   #3
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
^^^agreed. you will always find small things that you will need.
bl3ujay07 is offline   Reply With Quote
Old 02-04-2010, 07:53 AM   #4
kikcaffine
kikcaffine is an unknown quantity at this point
Grab new plugs also, probably an s14 oil pick up, make sure the pan is DEAD flat with no bends otherwise just bang it out when its out of the car, oil filter, possible a water pump, some of the lines that connect the valve cover to the built in catch can, changing the oil/coolant lines that goto the turbo while the engine is out of the car would simplify life greatly for changing the turbo in the future. Maybe some rocker arm stoppers also?
kikcaffine is offline   Reply With Quote
Old 02-04-2010, 08:18 AM   #5
Darksun280
Darksun280 is an unknown quantity at this point
I just started my project too. I didn't know I needed a new cluster guess I got more reading to do. Any one know a good site for source bolts for the S13 chassis I'm going to need the bolts that attach the rear end to the sub frame and the drive shaft.
Darksun280 is offline   Reply With Quote
Old 02-04-2010, 02:32 PM   #6
IketaniS13
IketaniS13's Avatar
IketaniS13 is a well-known jackass
I would definitely replace both your front and rear main seals before you drop that engine and also replace the seal on the tranny where it mates with the driveshaft. I would also replace all the gaskets as well, manifolds, turbo gaskets etc. Spend the money on the maintenance parts first before anything else.
Search the forum and do your homework.
IketaniS13 is offline   Reply With Quote
Old 02-04-2010, 02:56 PM   #7
Marc240
Marc240's Avatar
Marc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-known
Replace the water pump and gasket
http://i48.photobucket.com/albums/f209/mj2545/logo.gif.com
Marc240 is offline   Reply With Quote
