Old 06-12-2003, 10:09 AM   #1
FRpilot
FRpilot's Avatar
Aluminum Vs Steel
i want to start a debate between aluminum and steel parts. which one would you guys prefer and why? i know that aluminum is lighter than steel, but how strong is that stuff? my friend said aluminum is better than steel for certain parts. what i'm talkin about is suspension and bracing parts in particular. for example, would you rather have an aluminum strut tower bar or steel? how bout do-lucks tension gauge set and floor support bars. they have aluminum and steel versions. wouldn't steel be better since it should be stronger and thus stiffer for bracing? what im worried about is aluminum crumbling up under pressure. i would love to have a lighter car, but im not sure if aluminum is strong as steel for bracing purposes. how bout aluminum coilover casing vs steel. i was looking into zeal functions and they offer the b6 (steel) and s6 (aluminum). which one would you guys go with?
FRpilot is offline   Reply With Quote
Old 06-12-2003, 06:09 PM   #2
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
Roll cages are steel for a reason. To hell with metal... just go with CF. hahaha
RBS14 is offline   Reply With Quote
Old 06-12-2003, 09:03 PM   #3
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
Well, I'm by no means an expert in this area, so feel free to correct me, but here's my understanding.
Steel is ultimately stronger than aluminum, but it also tends to be more flexible at the same time. Therefore something like a strut tower, which doesn't take a huge amount of stress, but needs to be very stiff, is much better suited to aluminum than steel. Aluminum also has the benefit of being resistant, if not impenitrable, to rust. It's much lighter weight as well.
One must not forget, however, that the engineering of a part has as much to do with the structural integrity of something as the material that it's made from.
Learn everything you can, while you still have the chance.
transient is offline   Reply With Quote
Old 06-12-2003, 10:15 PM   #4
wpayne
wpayne's Avatar
wpayne is an unknown quantity at this point
I think transient put it very well. I too *think* that if the component can be engineered efficiently in a way that the structural rigidity/shape/etc is not compromised or where the component is not be pushed pass it's stress limit(like the tower bar) with it's given use, then go with aluminum. Have the advantage of it being lighter too.
If what you need is strength or where aluinum just won't do, go with steel(stainless of course).
edit: Then again, I gues there are sometimes(can't think of one now) where you need a little flex, a little give, to absorb some of the stress. I guess thats why you use steel when you need more strength. Okay, nevermind.
Too many people use cars as an extension of their PENIS and they make me sick. A car is to get you from point A to point B or for motorsports. Not revving around town at stop lights.
Check out my mods!: 50,000watt super amp and JDM lights!! Yeah right...
S13 Silvia K's I got for free (I'm in japan now)!! Woot woot!
'99 25GT-T Skyline (I don't want to list all the parts) http://welcome.to/skylinegtr
'92 240sx HB
wpayne is offline   Reply With Quote
Old 06-12-2003, 11:18 PM   #5
240racer
240racer's Avatar
240racer is an unknown quantity at this point
aluminum corrodes, but it's not called rust, because it's not iron oxide.
one must also not forget that almost every part you buy for your car is made more for how well it will sell then how well it will work. IN other words I bet not one of those strut bars has had an engineer do calculations on them. They are big enough that they look stiff and small enough that they look and feel light, that's it. if it matters then you need an engineer to do calculations, if not, then it doesn't matter what matterial it is anyway.
Just to further confuse the issue, which is stiffer a 1" tube of steel or a 1" tube of Al (same ID)?
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 06-13-2003, 12:24 AM   #6
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
steel is stronger, by far. try milling through aluminum and than try milling through steel. no contest. but if done correctly, an aluminum part can be lighter and stronger
to make it simple look at it like this
say you have a 1" diam tube, made of steel at a .125 wall thickness.that weighs 10lbs, and can support 1000lbs
you can have an aluminum bar, 1" diam., .275 thick, supporting 1000lbs, but weighing only 9 lbs
yes my numbers are a bit off, but for the sake of illustration
does that mean i would prefer an aluminum engine block to an iron block? not really, i would however prefer aluminum wheels to steel
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
Old 06-13-2003, 12:31 AM   #7
s13rookie
s13rookie's Avatar
also thou, flex is not ALWAYS a bad thing.
i used to be a big bmx'er. had a few alum frames, but most were good ol chromoly(4130). i was happy in the exchange between a few less pounds and stiffness versus a few extra pounds and a bit of flex, ecspeccially if a lil bit 'o flex would save you from snapping a head tube gusset
