Old 02-08-2010, 09:53 PM   #1
OregonS14Rockstar
OregonS14Rockstar is an unknown quantity at this point
s14 S14 Tach Prob
I let my 95 S14 sit for awhile and when i went to start it my tach didnt work. What could be the problem? What things do i need to check? thanks
And would anyone know what the little red thing is on the positive battery wire? And if its bad to take it off?
OregonS14Rockstar is offline   Reply With Quote
Old 02-09-2010, 03:24 AM   #2
projectRDM
projectRDM's Avatar
The 'little red thing' is just a plug, the two power leads for the master fusebox connect there.
The tach signal is generated within the distributor by the CMPS, start with an FSM and verify input to and from the ECU.
FORMERLY R240NA
Old 07-31-2010, 10:47 AM   #3
seanyroche
seanyroche is an unknown quantity at this point
did you solve this problem? I was looking at a non turbo s14a with a problem with the tacho. when switched on the needle goes all the way around the clock and doesnt move???? Help needed thanks
seanyroche is offline   Reply With Quote
Old 04-15-2012, 01:48 PM   #4
Zenki_cb
Zenki_cb's Avatar
Zenki_cb is an unknown quantity at this point
Help s14 tach
Hey I'm having the same issue my tach is all the way touching the clock needle. Did you ever solve this problem.
Zenki_cb is offline   Reply With Quote
