Old 02-12-2010, 05:01 AM   #1
Mosaic
Mosaic is an unknown quantity at this point
Need a Blow off MAF fuel corrector?
This really concerns those of us with MAF based fueling, not MAP based.
I have a new product option being prototyped, based around an electronic boost gauge. The unique feature of this combination boost gauge is a new controller.
First there will be the e-control for replacing a stock mech. BOV with an electronically triggered solenoid giving faster & boost-proportional response pre-vacuum for eliminating gear shift induced turbolag. This will be tunable for blow off sensitivity and blow off duration so you can precisely match your BOV performance to your application.
Interfaced with this BOV e-control will be a MAF interceptor which will reduce fueling to the vehicle based upon data from the BOV e-control. The amount of fuel reduction will be tunable as well to best match your application.
This method will solve the problems as described here:
Blowoff valve - Wikipedia, the free encyclopedia
Can you guys please comment and indicate if there are other features you would like to see?
Mosaic is offline   Reply With Quote
