Old 06-13-2003, 11:11 AM   #1
Uniac
Uniac is an unknown quantity at this point
Send a message via MSN to Uniac
rusted rockerpannels
ok here'sthe scoop, i just baught a 240 hatch, (got rid of my coupe) picked it up for 1500 cnd and the rockers are shot, you know the spot, right behind the doors rusted beyond repair. Problem is that i need to fix it the pass a saftey 'leagally.' Now does anybody know where i might beable to locate a supplier that makes'em or am i going to have to bend up a newe set. I Know i could got to the junkers and cut a set off, but problem is finding ones that are in good shape.
any ideas would be great.
thanks
Uniac is offline   Reply With Quote
Old 06-13-2003, 02:01 PM   #2
fooddude
fooddude's Avatar
fooddude is an unknown quantity at this point
Send a message via AIM to fooddude
Sh*t man, I got the same problem. My car looks mint outside, but behind the door and right in front of the rear wheels on the very bottom of the rear quarter panels I have very bad rust. One side is soo bad that if I stand next to my car on the side and look down into the bottom of the wheel well, I can see through the wheel well through a rusty hole. And when I wash my car that spot peels layers of dead metal, I eventually poked my finger though the panel. I sprayed it with wd-40 for now just to maybe slow down the rust growth till I get it repaired/paint job...but I have no money so i gots to wait.
fooddude is offline   Reply With Quote
Old 06-14-2003, 12:41 AM   #3
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
My 240 is totally rust free although my last car had the same problem
try going to a body shop and seeing what it will cost you. They can be "rebuilt"
that or try to mask the holes with some peel and stick louvers and vents like the honda kids use.
and get your car oilsprayed yearly, its very very good investment.
whatever you do, if you plan to keep the car do it right or else the rust will come back
best of luck
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 06-15-2003, 12:30 AM   #4
Uniac
ok, well i went buck wild with the sandblaster today (car's sea-foam green, er, um was)and blew the one on the drivers-side apart, i'm going to go to the wreckers and cut the peices off, flange it and weld them on to the prom-dress wonder.
I figure it doesn't need to be perfect cause my skirts will cover it, but it needs to be fixed to pass the safty. I'm still ganna try and bend up a set, cause it seems to be a common problem on the older 240's.
