stock piston ring gap
im putting together my spare sr20de+T and i wanted to get some info on my piston ring end gap. its stock replacement rings
my old ring gap 1st ring .015 2nd ring .021 new rings 1st ring .011 2nd ring .019 i checked the FSM and i noticed my new rings arent within standard spec. is it ok to run the new rings at their current spec since the original rings were also way below standard spec? heres a piece from the FSM. thanks for any help/advice ![]() |
The old ones weren't
the new ones appear to be just within spec I don't see a reason why not to run them if you want better clearance they you'll probably need to buy some and gap them yourself or have someone do it what pistons did they come with? |
its a new oem piston ring set for stock pistons and bore. Am i reading the FSM right? the top ring end gap (for example) should be .20-.30 and new rings are .11. a little too tight right? the thing that confuses me is my old rings were below spec aswell.
#6 |
![]() Join Date: Nov 2008
![]() Feedback Score: 16 reviews
When I built my 4g63 I ran them a little tighter than stock gap from what I can remember. If you run them too loose, you run the risk of piston slap when its cold.
#7 |
.8 seems a little too much. im thinking im going to have to get a ring grinder and gap them bigger to the loose end of spec. turbo engines require bigger end gap and the more boost the higher you need the end gap iirc. i think its to compensate for the added heat so the rings expand to give a good seal but not touch ends and fail.
i guess i have to grind the rings for a bigger end gap. its just wierd how small of a end gap the new oem rings came. Am i missing something here? ANY MORE ADVICE ANYONE? |
#9 |
![]() Join Date: Jul 2008
your rings are within spec. your not reading the FSM right. factory rings should not require any grinding unless your going with different bore.
your new rings: 1st ring .011 2nd ring .019 FSM specs: 1st ring .0079 - .0118 (limit .023) 2nd ring .0136 - .0197 (limit .027) when you read in measurements like this you want to round it off. there are some machinists that do this but id rather be most accurate then not. also i never read in millimeters. reading in inches give you a better accuracy |
#10 |
WTF? rex your right. i was reading the feeler gauge wrong. haha. this OEM brand gauge is tricky. how the hell did i miss that. haha damn i fail. thanks man.
atleast people can get the ring gap measurements from this thread haha |
