Old 02-13-2010, 09:05 PM   #1
YoungGun
YoungGun's Avatar
Tach Speedo Temp Sensor not working
Hey guys this shit worked before I put this new motor in but for some reason now it isnt working. The dash lights come on and I think the gas gauge works but everything else does not.
This is a problem because I don't have an aftermarket temp gauge, any help is appreciated thanks.
And I also have all 3 connections connected properly.
YoungGun is offline   Reply With Quote
Old 02-13-2010, 09:13 PM   #2
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
What motor, what chassis, with that said this could help..
If you swapped in a sr from a s14 into a s13 it could be the temp sensor is wrong, you need one that goes with you car(chassis) also if you put a duel cam, or sr20det in a sohc s13 the cluster(tach) wont work... speedo could be the vss(you need the one that maches the cluster you have, s14-s14, s13-s13, and so on)
Check fuses also...
Ceepo is offline   Reply With Quote
Old 02-13-2010, 09:17 PM   #3
YoungGun
YoungGun's Avatar
I checked all the fuses and changed out the bad ones, only difference is the clock came on the cluster.
It's a s13 blacktop and I have a jdm cluster, everything is the same from my last engine except it was a redtop and everything worked.
Old 02-13-2010, 10:00 PM   #4
Ceepo
Ceepo's Avatar
Wiring diffrent between the redtop and blacktop harnesses???
Old 02-14-2010, 08:08 AM   #5
YoungGun
YoungGun's Avatar
No same harness.
Old 02-14-2010, 12:05 PM   #6
YoungGun
YoungGun's Avatar
Any other suggestions i'm trying to take the car out tomorrow.
Old 02-14-2010, 07:18 PM   #7
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
so your using the same cluster but have a new motor. is there anyway you can take out your temp sensor out of the old motor? and did you keep the same tranny or get a different one with the blacktop? maybe you have the wrong speed sensor it wasnt plugged in.
rebornS14 is offline   Reply With Quote
