Old 02-18-2010, 04:19 PM   #1
stussy240
stussy240 is an unknown quantity at this point
high idle and check engine light issue
just rebuilt my KA to all stock. The motor runs and starts great but it automatically idles at 2k rpm and climbs to 2500 and stays there after awhile of running. the idle is smooth the whole time also. the check engine light comes on when going up to 2500 and stays on. I believe i have the timing set correctly at 20 when i set it i wasnt sure if the TPS needed to be connected or disconnected. i want to check the engine codes but forgot how to put the ecu into mode 3 so i can read the codes. any help is appreciated. thanks.
stussy240 is offline   Reply With Quote
Old 02-18-2010, 07:34 PM   #2
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
single or twin cam??
fcdrifter20 is offline   Reply With Quote
Old 02-18-2010, 07:36 PM   #3
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
check the MAF
jdm213 is offline   Reply With Quote
Old 02-18-2010, 08:12 PM   #4
worangejuice
worangejuice's Avatar
worangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond repute
Simple fixes are Idle adjuster screw on pass. side by firewall, 'wiggle' or mess with MAF, clean,etc., Check the IACV-clean with throttle body cleaner....or the stupid EGR valve...always a problem
http://i13.photobucket.com/albums/a253/worangejuice/sig-3.jpg
worangejuice is offline   Reply With Quote
Old 02-19-2010, 02:10 AM   #5
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
idle screw on iacv, maf, vac leak, or your throttle cable might be to tight ( the two nuts on the cable might be adjusted to high up) my friend adjusted his to high and couldnt figure out why the car was idling at 2800, make sure your touching the screw.
supreme_1 is offline   Reply With Quote
Old 02-19-2010, 04:15 AM   #6
stussy240
dual cam. And thanks for the input. I didn't have time today but I'll let you guys know how it goes and if I need more help. But for setting the timing does it matter to have the tps on or off? And how do you set the ecu to self diagnoistic mode
check engine light, ecu, high idle
