Old 03-04-2010, 05:59 PM   #1
anotheraznguy
anotheraznguy is an unknown quantity at this point
Send a message via AIM to anotheraznguy
twin turbo z33 25k firm
So some of you might know me and my car some of you don't
Asking price 25k Firm
No Joy-Rides
Test Ride w/ 25k cash in hand =)
You break it you buy it
Willing to trade for low mileage black interior f50 q45 or m45 y34 or y50.
Must be black interior + cash
Not parting out
Full list of mods to come when i have more time...
2005 350z Enthusiast
40k Miles
Chrome silver color
No Seat Airbags
Yes VLSD
Yes HID
NO Bose !!!! (Good thing)
at 5 lbs of boost car produces 377 hp and 341 lb-ft of tq
at 7 lbs of boost car produces 414 hp and 370 lb ft of tq
these numbers are at the wheels. with a 15% drivetrain loss calculated. you are looking at a car that produces almost 500 hp and 440 Lb-ft Of Tq on 91 octane pump gas Used only 76 gasoline as it is the best gas and help prevent detonation on turbo cars.
Car has been babied and garage kept.
Car has approx 40k miles.
Motul Oil used exclusively after breakin for tranny/motor/diff
Car was tuned by Sam @ GTM for reliability not allout power.
Car is professionally detailed with Zaino products at least twice a year.
Car was weighed in at 3300 with a full tank of gas.
Car is aligned once every 6 months and the alignment specs are
Front
0 toe
-3.5 camber
Rear
0 toe
-5.0 camber
Vertex Style Aero Kit glassed and hand prepped, sprayed and fitted with care.
Asuka carbon fiber full hatch with tinted rear window.
ARC titanium undertray for enhanced cooling and aerodynamics at high speed
Ame Tracer TM02 wheels
19x9.5 + 22
19x10.5 +22
in special order matte black.
Tires are BF Goodrich KDW tires
255/35/19 and 285/35/19
Tires are in pristine condition with full meat left
Wheels come with R40 Neo Chro Lugs and Locks
Suspension goodies include
Cusco front upper control arm to adjust camber
GT Spec Front fender brace to add to the already stiff chassis
Stance full coilover suspension with spare rear spring that is 2kg stiffer for track duties. This replaces the factory spring and puts it directly on the shock for better car control. coilovers are adjustable for spring preload and ride height.
Also damping adjustable to fine tune the suspension.
Hotchkiss adjustable sway bars front and rear. 4 adjustable slots in front and 3 in the rear.
SPC Rear camber bolt (will be included but not installed)
Now for the engine and drivetrain goodies
Espelir true dual JDM exhaust Deletes y-pipe. (with the body kit, this exhaust looks factory for less hassle from the police)
SGP full 3 inch downpipe (Bolts directly from turbo to start of exhaust (Deletes factory catalytic converter)
Spark Plug non foulers - This will allow you to not trigger any check engine lights being too rich.
SGP Wastegate dumps - This dumps the exhaust out of the wastegate when the boost pressure is reached. When boost is reached it gets loud! but is normally quiet when putting around town. a total jekyl and hyde conversion.
Tial Bov to help vent the boost out to the atmosphere.
CJM Stage 1 return fuel kit with aeromotive fuel pressure regulator and billet fuel rails
Walbro 255 fuel pump
RC Engineering 440cc Injectors
Turbo Xs Utec ecu
Turbo Xs Map Sensor
Turbo XS Map Switch
Turbo Xs Boost Sensor
This set of turbo xs goodies allows the engine to be tuned to perfection. The 5 bar map sensor is included as well as the boost sensor. It acts as a boost controller and can be controlled through the utec interface.
Apexi turbo timer. to help the car idle down after hard driving.
Spec Twin disk clutch capable of holding 1000 lb ft of tq
Spec lightweight flywheel (this combo actually does not make any noise at idle and is perfectly daily drivable in traffic)
Z1 Motorsports Stainless Steel Clutch Line for better repeatability in the engagement of the clutch.
Greddy Twin turbo kit
Greddy Polished Front mount intercooler
majority of piping/tubing/manifold/etc have either heat shielding to prevent heat from getting in or heat wrap to prevent heat from escaping. Install was professionally done and time was taken to ensure that no step was overlooked.
Motordyne 5/16 plenum spacer w/ tb coolant bypass. Add even more power without being overstated.
Pathfinder cooling mod to allow for even flow of coolant to both heads.
AMS 2 row full aluminum radiator
Z1 Performance Silicone radiator hoses
Replica Nismo Engine cover w/ stamped serial number.
APS Oil pan with custom -10An Drain lines to ensure there is never any backup of drained oil from the turbo
STRI Boost guage
STRI Oil Temp Guage
Both guages offer warning and peak hold, They also include a stepping motor and allows for daisy chaining of the guages to simplify wiring.
Innovative LC1 True wideband A/f Guage. one of the most reliable on the market
A-Pillar 3 guage pod for best visibility of engine vitals
Unorthodox Racing Underdrive pulley in Polished have it on Crank/Power Steering/Alternator
NGK 1 step colder spark plugs.
Brailled 15 Lbs lightweight battery.
ICE
Pioneer Avic D3 Navigation w/ Dvd player / Bluetooth
Professionally installed by me with tucked wires and hidden antennae. Ipod compatible and dvd mp3 player.
Clifford Avantguard alarm system with remote start - Top of the line alarm.
when sold, I will also include Factory front bumper / side skirt / rear bumper / factory headers / factory intake / Factory fuel rail / Aftermarket headers / Factory cats / Factory exhaust / Factory Headers / Factory Y Pipe / Factory Pulleys / Factory Suspension pieces as well. You will have all the parts to turn it back to stock.
You are getting a lot of Parts for 25k. Car runs excellent
Cons - need to pay to pass smog.. (after car is sold i will work with you personally(
Battery is tiny, i place it on a charger every night
Rear bumper has slight tear
no dings or dents, paint is chipped relatively.
call me at 510 676 5975.
let me know
Also, cf hatch is fading...
anotheraznguy is offline   Reply With Quote
z33 350z turbo
