![]() Join Date: Apr 2003
![]() Hey guys, I just installed an Injen CAI on my 98 240sx. Works fine but i still got the Inlet Air Temp. Sensor to worry about. What do i do? Would the AEM one fit on mine? and another problem is that it kinda pokes the bottom cover out. Also can i use the AEM Bypass valve on the Injen as well?
Thanks for the help.
98 Silvermoss 240sx [img][/img] |
I have the same intake as you on my 97 with the AEM Bypass. Some places I read said the piping needed to be cut for it to fit but I had no problems.
Signature deleted due to excessive size. 400x200 max limit! |
![]() Join Date: Jun 2002
I don't know if this helps but I have just put on a cone filter right after the MAF on the stock hosing. I did not unplug the temp sensor, but its not connected to the intake at all. The car runs fine, nothing is noticable from taking it off the intake, I'm convinced it doesn't do a damn thing at this point. I could be wrong. My point is that maybe going through the trouble of getting it plugged in isn't worth it.
-1997 240SX SE 5spd- ![]() -2002 Nissan OEM Gloss White Paint (June 2003) -OEM Nissan Front Lip -Type C Short Shifter -ApexI N1 Single Catback Exhaust -Test Pipe -Spec K Rear Wing -Kumho Supra Ecsta 712 ZR rated tires (205/55/16) -Eibach Pro Kit Springs -KYB AGX Struts -Llumar Centaur Premium Tint (28% front/20% back) -Alarm w/Keyless Entry -SOLD- |
#5 |
Autox Technician
![]() Join Date: Dec 2001
the temp sensor is only used for the on-board diagnostics. running with it completely unplugged may result in a CEL, but should not have any adverse affects.
My early OBDII '95 runs fine with the sensor completely unplugged. Runs fine with the rear O2 sensor unplugged as well (too lazy to ruin a Greddy DD welding a fitting in).
#6 |
whats a CEL?
#7 |
![]() Join Date: Mar 2003
It makes the splash guard poke out at the bottom because it does it on my 96. DO NOT take the guard off, i made that mistake and now i have to put it back on today... i dont know about the sensors because mine came with fittings to put them back on....with the Cold Air Extension and no splash guard you will suck water like you wouldnt believe....
1995 240SX SE - Sold |
