Old 03-11-2010, 11:38 PM   #1
MyNISMO314
MyNISMO314 is an unknown quantity at this point
s13 whining noise from SR!?!?
Looked at an SR20DET today that i was planning on buying ive seen it looks clean sounds really clean at idle BUUTTTT!!!...when you start to drive it and after like 5 minutes at idle it starts to make a really whining noise...i really dont know what it could be im just lost on this one...only thing i can come up with is maybe the turbo is going out since its just a stock t25...ill try to go again tomorrow look at it try to come up with a deal with the guy but until then i want some advice on this and ill try to post a video tomorrow if i go so you guys can see and hear of what im talking about. thanks in advance
MyNISMO314 is offline   Reply With Quote
Old 03-12-2010, 12:02 AM   #2
Sileighty_85
Sileighty_85's Avatar
does it whine when boosting?
Turbo probably is shot, Check for shaft play
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-12-2010, 12:29 AM   #3
hassanbakar123
hassanbakar123 is an unknown quantity at this point
could be something in the block, i've seen so motors start to whine from the bottom end once warmed up.
hassanbakar123 is offline   Reply With Quote
Old 03-12-2010, 12:43 AM   #4
MyNISMO314
whines at boost and at no boost...the owner thinks its cams but i just dont understand why the cams would whine or even anything in the block
Old 03-12-2010, 01:01 AM   #5
Sileighty_85
well the Cams will squeak if you have no oil flowing to the head.
Verify you have oil pressure and oil flowing to the head before driving that car any further
後輪駆動車1番
1986 SR86 - 200ish
Old 03-12-2010, 02:07 AM   #6
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
odds are its the belts. check the belts if they have slack. if so just tighten them
s13drob is offline   Reply With Quote
Old 03-12-2010, 11:37 AM   #7
MyNISMO314
how would the belts be the problem if they were off?
Old 03-12-2010, 12:08 PM   #8
abunai the drifter
abunai the drifter's Avatar
abunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-known
Send a message via Yahoo to abunai the drifter
I bet it the timing chain & guides
screw you guys im going drifting
abunai the drifter is offline   Reply With Quote
Old 03-12-2010, 12:10 PM   #9
slider2828
slider2828's Avatar
Check your belts..... My friends PS belt was slipping when he gas'd it too
Turn and Burn!
Old 03-12-2010, 04:21 PM   #10
MyNISMO314
its not the belts for the 5th time they were off and when on they were tight enough for it not to squeek or whine...BUT!!.the turbo has shaft play and an actual sr owner told me its the turbo in its early stages going out
Old 03-12-2010, 04:26 PM   #11
HAWAII
Trader Rating: (24)
HAWAII is an unknown quantity at this point
Feedback Score: 24 reviews
quick change to T28 double bearing.
HAWAII is offline   Reply With Quote
Old 03-12-2010, 04:28 PM   #12
MyNISMO314
exactly what i was thinking...anybody got a good t28 for sale haha
Old 03-13-2010, 02:38 PM   #13
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
Yea I second the turbo but it could be the rod bearings - they do good bad... and then they make a horrific whining noise - then a piston flies out the side of the block... speaking from experience...
rocksteady_racer is offline   Reply With Quote
Old 03-13-2010, 02:57 PM   #14
s13drob
s13drob's Avatar
Trader Rating: (29)
wait. you were running it with the belts off? really?
Old 12-15-2010, 03:04 AM   #15
MyNISMO314
this was the problem
turbo being held by one bolt and the gasket flapping around creating the whining noise as if you would put a piece of paper between your lips and blow haha
Old 12-15-2010, 07:57 AM   #16
holys14
holys14 is an unknown quantity at this point
It wouldntve been a rob bearing. I spun a rod bearing literally two weeks ago and its not a whining sound, its more like a knocking sound.. But hey at least you found out the problem, now go to t28
holys14 is offline   Reply With Quote
Old 12-19-2010, 01:40 AM   #17
MyNISMO314
Originally Posted by holys14 View Post
it wouldntve been a rob bearing. I spun a rod bearing literally two weeks ago and its not a whining sound, its more like a knocking sound.. But hey at least you found out the problem, now go to t28 :d
i just did just got it running today
