Old 06-21-2003, 09:38 AM   #1
96240sxSE
96240sxSE is an unknown quantity at this point
KA Opinions on Head Port and Polish?
Anybody have a ported and polished head? Looking for a little bit of info, since I'm gonna have a chance to port and polish at school, and its free. Wondering if it's even worth the effort, and what type of gains I could expect if I did do it. Any info would be appreciated. This is a (temporarily) stock KA. By the time I get to that class, I should have I/H/E and possibly some new cams.
96240sxSE is offline   Reply With Quote
Old 06-21-2003, 01:07 PM   #2
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
Do it! KA heads are quite restrictive from what i hear. Even if they aren't, you will still notice hp gains. Just remember when porting and polishing, your intake and exhaust manifold runners need to be port matched. i.e. the same size. Since you are not experienced in headwork, i would recommend just taking out casting marks then polishing, don't do too much porting. What you think would help with air/gas flow doesn't always help. Make sure not to hit your valve guides too, you do not want to replace those. Oterwise have fun and learn a lot!
RBS14 is offline   Reply With Quote
Old 06-21-2003, 03:02 PM   #3
kandyflip445
kandyflip445's Avatar
From what I've heard you don't port match the exhaust. Something to do with reversion?
My 240 vBgarage
Old 06-21-2003, 03:10 PM   #4
96240sxSE
Hmm, thanks for the info so far. I have 6 months to think about it, I may be dropping new cams in at the same time, and don't want to screw anything up. Anybody else have any info on doing head work?
By the way, a little OT, but if anybody wants to go to an automotive tech school, check out WyoTech. The scenery sucks, but the schooling is great. I'm taking Chassis Fabrication/High Performance Engines after my automotive core.
Old 06-21-2003, 03:35 PM   #5
Roly
Nuclear
Roly is an unknown quantity at this point
There are quite a few stock head KA's running 12's and 13's. I suggest a mild p&p, with stock 91 KA cams for best results.
RACECAR spelled backwards still spells RACECAR
Roly is offline   Reply With Quote
Old 06-21-2003, 05:58 PM   #6
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
how about Duy's old 10sec car with a stock head?
AceInHole is offline   Reply With Quote
Old 06-21-2003, 06:01 PM   #7
AceInHole
Autox Technician
AceInHole's Avatar
Yeah, the exhaust side generally isn't port matched unless it's going to a smaller port, i.e. large head port opening to a small manifold port opening. This is so when the exhaust gas travels back between pulses, the mis-matched port acts as a "wall", helping keep exhaust gases going out instead of in.
Edited in:
Anyways, if you're taking a class about it I'm sure you'll learn in there.... but the quick run through:
intake ports: should be rough to the touch (helps atomized gas to mix with the air flowing in). Casting peices in the bowl area above the valve are where you'll have to do the most work.
one wall done:
exhaust ports: should be mirror smooth to help keep carbon deposits from sticking. I forgot where but there's a decent hump in the port that can be flattened out. I recall it being somewhere behind the divider.
When I ported my old head, I folloed this guide: http://www.sa-motorsports.com/diyport.htm
Good luck!
Old 06-22-2003, 11:23 AM   #8
96240sxSE
Thanks for the info guys, gonna have to think about it, I don't want to screw up my head, cause I sure don't have the money to replace it.
How hard is it on a scale of 1-10? 1 being an oil change, 10 being a full rebuild.
