Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 03-16-2010, 04:12 PM   #1
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
2 seater hatch fit a 2+2?
does anyone know if the two seater 300zx hatch can fit on a 2+2?
supreme_1 is offline   Reply With Quote
Old 03-17-2010, 02:14 AM   #2
DeleriousZ
DeleriousZ's Avatar
DeleriousZ is an unknown quantity at this point
Send a message via MSN to DeleriousZ
z31 or z32? z31 = no
DeleriousZ is offline   Reply With Quote
Old 03-17-2010, 04:48 AM   #3
supreme_1
z32
msg length
Old 03-17-2010, 04:53 AM   #4
saruz
saruz's Avatar
saruz is an unknown quantity at this point
negative reason is because the length 4,305 mm (169.5 in) 2 seater 4,520 mm (178.0 in) 2+2 hope this info helped you out =]
saruz is offline   Reply With Quote
Old 03-17-2010, 05:04 PM   #5
supreme_1
i was hoping that the hatch was the same, whiloe the wheel base is where they extended it.
can anyone chime in who knows specifically about the hatch. the length of the entire car is a little vague as they might have stretched it in different areas.
Old 03-17-2010, 11:38 PM   #6
saruz
saruz's Avatar
the car is stretched from the T-top profile, on the 2+2 it is not as arched as the 2+0 its not as steep. window it is larger and has a different profile on the 2+2. fender in front of the rear tire there is more fender there by i think 10 inches also this is where the filler cap is on a 2+0. rear fender, on the 2+2 this is where the gas filler cap is on the drivers side and it is also a little longer than on the 2+0 but its hard to tell the difference visually. If that's still too vague for you LMK
Old 03-17-2010, 11:59 PM   #7
babyjesus
babyjesus's Avatar
babyjesus is an unknown quantity at this point
^^not too vague at all, but simpler said, no it wont fit.....the z32 2+2 is only the same from the door forwards
thelittlebigblock.blogspot.com
babyjesus is offline   Reply With Quote
