Old 06-22-2003, 10:16 PM   #1
wingsnthangs
wingsnthangs's Avatar
wingsnthangs is on a distinguished road
Send a message via AIM to wingsnthangs
s13 Brake/Stop Lights not working
As the title says, my brake lights fail to work, and I dont know when this started happening, just found out last night.
1. Checked fuses and fuse box under the left side of the dash, theyre OK.
2. Checked bulbs, they work too.
3. When my headlights are on, the rear bulbs are on, as normal. Nothing changes when I depress the brake pedal.
According to Chilton's manual diagram, there is a set of switches under the driver's side of the dash, including the stop light switch. However, I cannot locate this as when I take a look under the dash, it represents nothing like the actual diagram.
If i could locate that little switch, it may very well solve my problem. Or can the problem be something else? Can anyone help? Thanks in advance.
wingsnthangs is offline   Reply With Quote
Old 06-23-2003, 08:23 AM   #2
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
Check the power output going to the bulbs when the brakes are depressed, see if you are getting current.
Check the switch which is attached to the brake pedal, that is what activates the brake lamps.. make sure that the switch is working.
If your parking lamps work, your circuit should be okay because the brakes and parking lamps I *beleive* are on the same circuit.. same fuse, etc. I dont think there is a relay, but there may be.
Chiltons is crapola, an FSM would be much more useful in trying to resolve this problem.
- Mike
old_s13 is offline   Reply With Quote
Old 06-23-2003, 08:39 AM   #3
muskrat
muskrat's Avatar
muskrat is an unknown quantity at this point
Were they recently working and this just happened or what?
muskrat is offline   Reply With Quote
Old 06-23-2003, 11:57 AM   #4
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
did you recently install a new deck in your car?
thats what screwed up my taillights was a new CD player....something was gtounding out or something
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 06-23-2003, 02:20 PM   #5
wingsnthangs
Thanks for all of your responses
How do I check if the switch is functional? How do I test it?
I really don't know, but I do know they were working. I only found out about this problem 2 nights ago, when my friend driving behind me told me that my brake lights were not working. How else would one know if their brake lights are working? It's like having the back of your head dyed neon green; chances are you wouldn't suspect it unless someone else told you.
No. I have not messed with my car's audio electronics since I purchased it over a year ago. And I know for a fact that my brake lights were working a few months ago.
Old 04-03-2004, 01:44 PM   #6
iluvdrifto
iluvdrifto's Avatar
iluvdrifto is an unknown quantity at this point
im having the same problem too checked the same stuff ... by any chance have you fixed it ?
iluvdrifto is offline   Reply With Quote
