Old 03-21-2010, 11:46 PM   #1
pinkarrowsnow
pinkarrowsnow's Avatar
pinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura about
Dumb clutch problem helppp!
Ok guys got my sr swap in and running awesome tonight ran into one problem. Put a s14 master in the car (its a s13 dont think that matters) with stainless lines to slave. Bled for a long time if you push clutch in hard it will come up fine but like normal conditions it will stick to the floor and feel like it hasnt been bled blah blah. Any ideas of where to search first for this problem? Please help ive driven my built ka and wanna see how much better the sr is haha.
Thank you
pinkarrowsnow is offline   Reply With Quote
Old 03-22-2010, 12:08 AM   #2
sil80 monster
sil80 monster is an unknown quantity at this point
check the slave cylinder
sil80 monster is offline   Reply With Quote
Old 03-22-2010, 12:19 AM   #3
mazersx
Banned from the Marketplace
Trader Rating: (32)
mazersx is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to mazersx
check the slave cylinder, but mainly check for AIR!!
mazersx is offline   Reply With Quote
Old 03-22-2010, 12:23 AM   #4
zerooath
98 Kouki Slicktop. Tip Dealer!
zerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to all
Send a message via AIM to zerooath
Slave Cylinder.
If you press the clutch in and the fluid in the master cylinder moves then chances are its prolly not your master cylinder.
Check the slave cylinder for small leaks. It could also be leaking from inside the rubber boot and you may not be able to see it. You can take the small boot off and look that way.
zerooath is offline   Reply With Quote
Old 03-22-2010, 12:27 AM   #5
pinkarrowsnow
thats what i was thinking too somewhere along the trip from my friends to my house it got pushed out and needed to push it in pretty hard with a c clamp and fluid in master does move but i checked the boot sorta didnt see fluid ill check in the morn. BTW does anyone know if i can use my stock s13 slave and put my stainless line onto it?
