![]() Join Date: Jul 2008
Trader Rating: (41)
![]() Feedback Score: 41 reviews
Spark Plug Heat Level & Gaping
This is my current setup:
SR20DET T25 Turbo (10psi) FMIC Stock MAF Stock Injectors Stock ECU Stock Intake Stock Pulleys Stock Cams Greddy Profec-B Walbro 255lph Fuel Pump / 300ZX Fuel Filter Megan Exhaust Manifold Greddy Turbo Elbow Megan Downpipe 3" Exhaust This is my near future setup: SR20DET T25 Turbo (10psi) FMIC 300ZX MAF 550CC Injectors PowerFC L-Detro Apex'i Power Intake Megan Pulleys Tomei Poncam Stage 1 (256/256) & Rocker Arm Stoppers Greddy Profec-B Walbro 255lph Fuel Pump / 300ZX Fuel Filter Megan Exhaust Manifold Greddy Turbo Elbow Megan Downpipe 3" Exhaust Which heat Heat Levels and Gapping should I be using for each setup? Thanks |
![]() Join Date: Dec 2006
Stock Plugs Heat Range 7 gaped at .28
why upgrade everything else and keep the T25 at least get a T28
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
If you're going to upgrade everything else, go with the T28 turbo. They can be had relatively cheap and FRsport.com sells install kits with everything needed to install it on your S13.
#4 | |
Trader Rating: (41)
Any heat specification for higher modified engines? EDIT: I forgot to mention that my 'near future setup' is all parts I have already. |
#5 |
#9 |
![]() Join Date: Sep 2008
i actually had a question about this... i heard some one tell me for boosting you car its best to use colder plugs ... is this true ?? im new to boost so im kind of in the dark with getting my set up done right. not to impose on this thread.. just a quick question
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
#10 | ||
Heat range 7 at .028 gap is where you should be and you won't need anything colder until you're well into the 400hp realm. Quote:
I run 7's and dyno'd 360rwhp at 13psi to give you an example.
#11 | |
Trader Rating: (41)
7 @ .028 it is, thanks! ![]() |
#12 |
![]() Join Date: Jul 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 9 reviews
Dont waist your money on Iridium plugs. The shop I have my car tuned at runs NGK copper plugs on their 1000hp supras just fine. I think they are 4464(bkr7), like a dollar and some change and gap .28
#13 |
Depends how you view it. Copper tends foul much early than Iridium IMO. Iridium will be best if you want to just put the set and not worry about it for awhile. High HP cars you kinda need to check and replace those things more often so cheaper plugs wil be better. Daily setup go with Iridium last longer and not risk stripping thread on the head.
