Old 06-27-2003, 04:06 PM   #1
TropicalJewel
TropicalJewel's Avatar
TropicalJewel is an unknown quantity at this point
no start ideas...need some
Hey peoples,
I am in need of ideas as to why my car won't start up right away. It could take up to 15 minutes b4 it starts. I turn the key and not a sound. I keep doing this until all of a sudden the car just starts like it was my first try. Like I said sometimes from 5 minutes to like 15 minutes before it starts. The battery is a new one. Otherwise I guess I have to take it into the dealer cuz I don't get it. So got any suggestions or ways to try and figure out what is up with the car? It is a 95 240sx with like 82,000 miles. I was almost thinking that maybe the neutral sensor is jacked or somethin. Just a wacky thought.
Thanks,
Monique
TropicalJewel is offline   Reply With Quote
Old 06-27-2003, 04:08 PM   #2
Apparition
Apparition's Avatar
Apparition is an unknown quantity at this point
Send a message via Yahoo to Apparition
I had this exact same problem. Flat spot in the starter. Click it over fast, and it should kick in. Get a local garage to test it for you.
1990 240sx coupe *sold*
Apparition is offline   Reply With Quote
Old 06-27-2003, 04:42 PM   #3
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
My bet is on corrosion on the battery or starter terminals.
DuffMan is offline   Reply With Quote
Old 06-27-2003, 09:04 PM   #4
radhaz
radhaz's Avatar
radhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud of
I have this problem whenever I faulk around with the battery, it turned out that the "corrosion" that had gotten on my negative terminal was enough so that if I didnt go nutzo when cranking it down the car wouldn't start. So like duffman suggested check your battery leads.
radhaz is offline   Reply With Quote
Old 06-27-2003, 10:52 PM   #5
TropicalJewel
I think it is safe to say that I can rule out corroded terminals and battery. When I replaced the battery last weekend I gave both terminals a good cleaning. Not much cleaning was needed for only the positive was a bit grungie. I guess I can look into the starter idea. So where should I look for something like that?
Mo-
