Banned from the Marketplace
![]() Join Date: Oct 2008
Trader Rating: (32)
![]() Feedback Score: 32 reviews
![]() ***Complete part out of Nissan 240sx S13 and s14 s15 Silvia front ends***
Send me a PM OR leave a message Here. I have many more parts that aren't listed.. S13 = 1989-1994 S14 = 1995-1998 S15 = 1999-2002 Exterior: (**Front ends, Bumper, Fenders, Hood, Doors, Rear quarter panel, Rear bumpers**) s13-s14-s15 S13 Front clip Aka Radaitor Support with Apron $120 obo 89-94 NO FRAME DAMAGED out of a 1991 se S14 front clip aka radaitor support with apron $200 95-98 NO FRAME DAMAGED out of a 1996 se - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Headlights pop up S13 headlights $40 95-96 S14 zenki headlights no broken tabs $200 89-02 S15 Silvia Headlights $600 No broken tabs - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Fenders (fender linner, metal fender, fiberglass, bracket, screws,) 89-94 Driver side Metal fenders $50 passenger $20 has dent 95-96 driverside fender $80 oem green passenger fender $20 has dents 95-98 s14.5 Fender fiber glass driverside only $20 95-98 s14.5 Converison Fender fiber glass Vent 20mm only $150 obo S13 GOOD CLEAN fender linner - $20 each s14 fender liners all around with bottom guard $50 no damaged Exterior - Rear metal quarter panel 89-94 rear hatchback $80 pick up only driverside Rear metal quarter panel 95-98 rear $200 pick up only driverside and passenger Rear quarter panel WIDE BODY B-Magic Aero 30mm 95-98 FRP FENDER $250 obo CLEAN - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Hoods (Fiberglass, oem metal, carbon fiber) 89-94 s13 pop up headlight hood 240sx $40 95-96 green zenki hood $150 obo - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Rear trunk (glass, hatchback, Trunk lid) sunroof glass no RUST OEM NISSAN 95-98 $200 89-94 clean wingless coupe trunk $100 obo 95-98 wingless trunk s14 $100 obo 95-98 oem peral white 1996 se trunk with spoiler $150 95-98 oem Green/blue se trunk with spoiler $150 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Bumpers (bumper cover, metal bumper support reinforcement, foam) s15 89-02 Front bumper $40 fiberglass has minor cracks Spec r replica 91-94 240sx Pop up headlight, Chuki Front bumper with SE LIP $150 89-94 Rear Coupe/convertible bumper Clean $80 89-94 front $20 or rear bumper support $20 each S13 240sx bumper support foam $20 Jdm zenki bumper $200 No broken tabs.. Direct bolt on to 95-96 usdm car USDM ZEnki bumper $100 ZENKI BUMPER/HEADLIGHT RETAINER CLEAN $75 Tail Lights d-max style LED 180sx tail light $200 obo left and right (hatchback) ![]() 89-94 tail light $100 a set! OEM obo coupe, convertible, hatchback 95-98 S14a Kouki Complete TAIL-LIGHT $350 obo - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Doors (motor, window, switches) 89-94 clean pasenger door with manual tinted windows - $100 complete clean clean white paint 89-94 Power windows Doors Complete - $300 a set complete door and harness, motor/ regulater/ tinted glass included Mirror 89-94 driver/passenger side mirror - $40 each power or manual 95-98 driver/passenger side mirror - $40 each Interior (*Seats, interior panels, arm rest, center piece, dashboard, etc**) 89-90 single cluster $60 95-98 white face cluster SE ~114k $200, ~162k $130 97-98 kouki base model cluster $80 ~175k Clean black cluster trim $30 95-98 Arm rest $40 8 out of 10 Nissan 240sx 1989 - 1994 Hatchback, Convertible, Coupe A/C CLIMATE CONTROL - 89-94 $30 95-98 $50 89-94 OEM coupe quarter window glass - $80 each obo hatchback rear black quarter panels - $30 each or $50 for both 89-98 Glove box $20 Nissan 240sx 1995 - 1998 Zenki, Kouki S14a Door Panels -$50 a set rear black quarter panel - $40 for both (interior) Airbag Driverside and passenger r - $200 or 150 each passenger side no cracks 1/4 quarter panel glass- $30 automatic gear shifter - $20 Internals: ( **Engine, Transmission, Brakes, Suspension, Control arms, Axle**) s13 abs brake module/system $40 no problem whatsoever.. Complete 5 Lug Conversion $500 fits all year 1989-1998 Brake System - - - 89-98 S13 Stock Front brake caliper with brake pad $25 each or $40 for both - - - 89-94 Rear caliper $40 each. GOOD SEAL NO LEAKS!l - - - Front 180sx big piston caliper $100 pair WITH 4 lug ROTOR - Engine and Transmission 1996 SE 114k Clean engine Low mileages complete swap with auto tranny $700 1995 SE 162k blown headgasket complete swap $550 complete swap with auto transmission 1990 Sohc complete engine swap with bad head $200 with auto transmission 1990 sohc ~129k running health engine no leaks $450 motor only. NEW Delrin Stiff Motor Mounts KA/SR Direct bolt on - $100 A SET 91-94 Automatic Transmission with only ~73,xxx $200 89-90 KA24E Clutch + Flywheel kit $80 ![]() 89-90; 91-94 single cam 240sx stock header - $30 89-98 starter $50 ( working condition can go with you to autozone to test it out.) 91-98 twin cam header shield - $20 off a s14 1995 91-94 S13 dohc down pipe weld to your exhaust- $20 MAF (mass air flow sensor) SOHC 89-90 $60 , S14 97-98 $200 [SIZE="4"- Engine and Transmission[/size]-Front + Rear Suspension [SIZE="4"- Engine and Transmission[/size][/size] 89-94 Apexi Coilovers N1 Nearly NEW $1200 obo ~300 miles ![]() 89-94 Teins Drift Spec Coilovers $800 ~11,000 miles S13 subframe clean $100 ; S14 $150 95-98 $130 each ,89 -94 open diff aka 3rd member, pumkin COMPLETE $80 each 89-98 s13, s14 6 bolt axle $35 each s13 or s14 Stock shocks and spring $150 obo Complete front and rear. 89-94 s13 rear control arm $50 each s14 $100 Each s13 or s14 traction arm, toe arm, camber arms - $20 each. s13 hub+spindle - $40 each side.or $150 for complete s13 front lower control arm -$35 each s13 front/rear sway bar - $20 each Exhaust System OEM CAT $140 Aftermarket cat converters $20 89-94 Coupe, fastback, hatchback, convertible Rs-R GT-2 Full catback $350. DIRECT BOLT ON OEM SETTING Donuts/ Spare $20 each. Stock steelies - $20 each (tires will need replace) ![]() ![]() ![]() ![]() ![]() ![]() rolling shell with paperwork $800. Tag expired may 2010. |
