Old 05-05-2010, 08:52 PM   #1
Nibras
Nibras's Avatar
Nibras is an unknown quantity at this point
Send a message via AIM to Nibras
s14 Window amp question
i have a 96 240sx.
my window switch stopped working for my driver side but my passenger side window still works.
i replaced the whole switch in the door and that did nothing
i was told to replace the amp , i took the door panels off of both sides and can not locate the amp , it is not on niether door!
if anyone has any idea of if someone b4 relocated the amps or if they replaced it with a different amp or any input at all i am very confused!
Nibras is offline   Reply With Quote
Old 05-05-2010, 08:58 PM   #2
Leo-kun
Leo-kun's Avatar
Leo-kun is an unknown quantity at this point
Do you know what the amp looks like?
it should be a small white box with a harness plugged into it.
Leo-kun is offline   Reply With Quote
Old 05-05-2010, 09:02 PM   #3
Nibras
Nibras's Avatar
ya i have one my friend gave me right next to me, i looked on the door and found where the amp would be pinned but its not there
Old 05-05-2010, 09:02 PM   #4
Nibras
Nibras's Avatar
also i dont even see the harness that plugs into it and i followed all the harness and still nothing
Old 05-05-2010, 09:20 PM   #5
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
u might have a bad motor
feed the motor directly with 12volts via drill battery works
if it does not move you have a dead motor
then i can fix it for $40
built ka-t
importdude is offline   Reply With Quote
Old 05-05-2010, 09:22 PM   #6
Nibras
Nibras's Avatar
how do i feed it 12 volts?
Old 05-05-2010, 09:41 PM   #7
importdude
importdude's Avatar
any cordless drill battery or your car battery
use wire lol
its 2 pin any ground and power in any order/position
it will either go up or down
if you get no response then the motor is dead
built ka-t
power, s14, stuck, window
