Parts Shop MAX ~Flush Wheel Fitment Parts~ Adjustable Wheel Spacer & Fender Roller
![]() PURCHASES AND SHIPPING QUOTES DIRECTLY FROM THIS THREAD! SIMPLY CLICK THE BLUE ADD TO CART LINK VIEW CART MAXワイドトレッドスペーサー強化ボルト仕様!! Aggressive width wheel spacers are a must for those who desire the clean “Tsuda-Ichi” (Japanese for “paper thin” gap) flush wheel to fender look without buying an expensive set of custom width wheels. Parts Shop MAX precision CNC machined aluminum wheel spacers are lug and hub centric. They are available for a wide variety of cars, so make sure you get the correct size. We now offer 66.2 center bore with 4 or 5 1.25 thread studs for Nissan S13, S14 etc. 66.2 center bore with 5x1.50 thread studs for Toyota Supra/SC, FC RX7 and similar makes and also 67.1 center bore with 5x1.50 thread studs for Hyundai Genesis and similar cars. Features hardened steel studs and lug nuts all with a PCD of 114.3mm. The next generation of wheel spacers are adjustable width! Now you can have great fitment with several sets of wheels despite differences in offset without buying more than one set of spacers. When you send the rear of your car sideways into somethig and it just dont look the same on both sides, you can run slightly different widths left and right. Drifters are always coming across new tires they want to try, but each brand has a different side wall profile, or some tires on sale where we cant be too picky about the exact size when it comes to price, however if you have super flush fender flairs or body work, they may rub too much so its really nice to be able to pull out a slip on from the stack and prevent rubbing. Also if you wanted to try stretching you tires a little more you can go down one size and add a slip on spacer maintaining your hella flush look without redoing bodywork & paint. If you are like us you cant resist switching up your style by buying and selling used wheels, and these adjustable spacers will make sure that whatever wheels you come across, you dont have to make any compromise in fitment. There are so many factors in wheel fitment including what chassis parts you have, ride height, alignment, offset, wheel diameter, tire size, brand etc. that is really nice to have the new found flexability and fitment control that the Parts Shop MAX adjustable spacers gives you. We used to sell 15, 20, 25 and 30mm bolt on spacers which people loved because of the quality and slightly lower price, but this single set is capable of 14 different widths by combining one 15mm bolt on with long studs and a 3,5, & 7mm slip on. We dont like to rest on our achievements, instead we want to bring you the best most innovative parts while still maintaining a great value. Some other companies make this in Japan, but they are very expensive and not as pretty. They have casted slip on spacers instead of CNC machined & anodized aluminum for the complete set. We felt its necessary to maintain a perfectly flat surface between all the spacers so we offer a more precision finish than the other JDM manufacturers. Possible sizes when combining these four sizes are: 3,5,7,8,10,12,15,18,20,22,23,25,27,30mm We sell components of the adjustable set individually, the pricing per pair of each size within the set is: 15mm $80 7mm $40 5mm $25 3mm $15 The above price for the individual components is displayed in the shopping cart after you 1.Click the blue underlined ADD TO CART text below, 2.Make your selections and then 3.Click the grey "UPDATE" button. Complete 8 piece 30mm special set price (for two wheels) is $150 MAX Adjustable Wheel Spacers $150 in stock date is 5-13 ADD TO CART < click to quote with shipping or to place an order ![]() ![]() ![]() ![]() The way to achieve the perfect Tsuda-Ichi style is to bend the inner lip on the quarter panels and fenders flat against the outside skin. The most unique and vital feature of the MAX GEN II FENDER ROLLER is that it is the only fender roller in the world that is convertable for use on extremely low cars. Most fender rollers are only designed for use on factory height vehicles forcing coilover equipped vehicles to raise up to stock height to roll the fenders creating extra work. The roller angle is especially suited to bending the lip as flat as possible against the surface to give your car the ultimate flushness. The urethane rollerbearing wheel is strong enough to bend metal yet soft enough to prevent paint damage on most cars when used in conjunction with a heat gun. The roller is a must for fitting low offset wheels. For cars utilizing standard offset wheels, use MAX Tsuda-Ichi wheel spacers and the MAX fender lip roller to create that hella-flush JDM look on your car. For 4 or 5 lug hubs with 98-125mm stud spacing. Update! The first fender roller specifically designed for lowered cars is already in its second generation with many improvements making this the best wheel fitment tool money can buy... MAX Fender Roller Generation 2 $220 IN STOCK NOW ADD TO CART < click to quote with shipping or to place an order MAX GENERATION II FENDER ROLLER TOOL ~ NEW PART DEBUT! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() **UPDATE** We are now shipping a new spec GRAY roller wheel that is +2 durometer points harder. Price and all other features remain the same. The new replacement wheels are available for $13+sh in Grey only. Feel free to order while the shipment is on its way here and we'll dispatch the roller equipped with the new wheel to you as soon as they arrive. ![]() ![]() ![]() Parts Shop MAX *NEW* fender roller & adjustable wheel spacers featured in Super Street April 2010 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() VIEW CART
![]() Join Date: May 2006
Excellent products, excellent support here in the states. Love PSM.
#5 |
wow this is very cool!!! love the spacers
@UpshiftEngineering |
#7 |
Maybe I missed this but you also have 5x114.3 spacers?
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’ Jeremy Clarkson on Automatics |
#9 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
HEy dan do you sell 10mm slip ons?
Slip Gypsies Blog Quote:
#11 |
thanks guys!
15mm, that's the depth of the stud splines so it does not make sense to go smaller when there is studs no we stack 3 and 7 to make a ten we certainly do, you can order directly from this thread when you click the blue "add to cart" text
#14 |
lol mr. famous
thanks for your business!
#16 |
im guessing thursday. call before you come to double check
#18 |
they are here (in the nissan thread pitch) stock of mazda, toyota etc to follow shortly - coming by ocean.
#20 |
yup 5 lug too. I think you already picked them up.
#22 |
nice work gettin' while the gettin's good wonderbread...
5 lug bolt ons from the air freight that just arrived are sold out BUT still have slip ons in stock Also, Plenty of 4 lug bolt ons here as well. More 5 lug spacers are coming in 2 weeks.
#24 |
![]() Join Date: Mar 2002
please let me know about the 2 sets of the 5 lug spacer kits..
shipped to 94555 also, wanted to know what the centerbore is, is it hubcentric, is it a 12x12.5 thread pitch? thanks looking at picking this up for the z33 |
#25 |
![]() Join Date: Apr 2006
need 4x100 1.5
2015 Subaru Outback Overlander - Wagonofdoom |
#26 | ||
from the first paragraph in the OP... Parts Shop MAX precision CNC machined aluminum wheel spacers are lug and hub centric. They are available for a wide variety of cars, so make sure you get the correct size. We now offer 66.2 center bore with 4 or 5 1.25 thread studs for Nissan S13, S14 etc. 66.2 center bore with 5x1.50 thread studs for Toyota Supra/SC, FC RX7 and similar makes and also 67.1 center bore with 5x1.50 thread studs for Hyundai Genesis and similar cars. Features hardened steel studs and lug nuts all with a PCD of 114.3mm. Z33 is like the s chassis spec - all of these specs are selectable in cart. whats that for?
#27 |
miata.....id much rather buy your shit than ebay
#28 |
I'll put in the request if youre not in a hurry ... like 2 months
ALL SPACERS ARE IN STOCK NOW !!!
#29 |
![]() Join Date: Jul 2008
Just want to confirm you have stock on the 2 of the 4 lug spacer kits with all of the plates. (i want to adjust up to +30 on all 4 corners)
When you confirm this I will be placing an order. Thank you.
SCAMMERS MrFuel sold me a cracked manifold geoff240sx sold me a blown turbo |
