Old 07-12-2003, 09:43 AM   #1
TrustSupra
TrustSupra is an unknown quantity at this point
SR Vacuum at idle question
When I'm not under boost, just sitting at idle what should my vacuum be at in PSI its at 10in.HG Vacuum right now at idle. Someone told me it should be at, at least 20inHG Vacuum or else i have a vacuum leak?
TrustSupra is offline   Reply With Quote
Old 07-12-2003, 04:44 PM   #2
HNismoGTR
HNismoGTR is an unknown quantity at this point
hmmmmm..... anyone?
HNismoGTR is offline   Reply With Quote
Old 07-13-2003, 03:48 PM   #3
240_keyy
240_keyy's Avatar
240_keyy is an unknown quantity at this point
Send a message via ICQ to 240_keyy Send a message via AIM to 240_keyy Send a message via Yahoo to 240_keyy
yes, whoever told you that is correct. With my SR idling at 1000rpm I sit at about 22in/hg It could definitely be a vacuum leak so check that first. then again, if you were leaking that much you would have other problems like low irratic idle and boosting problems.
There *is* a spoon...
240_keyy is offline   Reply With Quote
Old 07-13-2003, 09:43 PM   #4
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
Yep - Mine is S14, KA-T, 20in/hg...
Pressure test the intake mani / intercooler piping...use something to block the turbo inlet, and pressurize with an air compressor. Find the leak, fix it...
Later - Brian
orion::S14 is offline   Reply With Quote
