Old 05-21-2010, 01:42 PM   #1
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
Godspeed Project 18G Turbo Dyno Test!!
Godspeed Project 18G, Car we used is Riley S13 Red Top SR20det , Dyno Done @ Reggie From OSR , Sea Level 4000+
Dyno # 1
Dyno # 2
Dyno # 3
For The Best Price, Please PM or Call US !! (when you call make sure you say you are from Zilvia.net for the best discount!!
We are S13/S14 Specialist, if you cant find what you need check out our website GodSpeed Project - Intercooler, Turbo Kits, Turbo Manifold, Body Kit or give us a call if you have any question!!
We also have other GB on the forum, so please check them out!!!
Ken @ Fatboy Garage Motorsport
2518 Continental Ave
El Monte CA 91733
626-442-3988
Fatboy Garage is offline   Reply With Quote
Old 05-22-2010, 09:23 AM   #2
2mtx12
2mtx12 is an unknown quantity at this point
im going to be picking this turbo up soon whats max boost and how much power?
and will the stockk inlet and outlet fit on this turbo/ also when is full boost kick in?
2mtx12 is offline   Reply With Quote
Old 05-24-2010, 10:46 AM   #3
Fatboy Garage
Here spec
Bearing system: Journal Bearing
Compressor Wheel Diameter: 50.3 / 68mm
TURBINE Wheel Diameter: 49.2 / 56mm
Turbine TRIM: 57
Turbine flange type flange: T25
Downpipe flange type : 240sx 5 bolt type
Nozzle Area: 8cm²
Cooling type : oil and water cooled.
Horsepower rating: 300-380 hp
BOLT ON TURBO FOR S13 S14 S15 (SR20 MOTOR)
Actuator set at : 14.5 PSI
CFM: 600
Old 05-24-2010, 11:10 AM   #4
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
few quick facts
Install was simple and direct bolt on
The car made just a hair more then advertised( not a bad thing right! 306rwhp so approx 340 the the flywheel
I'll be turning up the boost to 20psi in the coming weeks with a ROM tune and post new dyno sheets.
overall a great product and im thankful to test and help godspeed make a better product.
Grenade180sx is offline   Reply With Quote
Old 05-24-2010, 03:23 PM   #5
D.Adams
D.Adams's Avatar
D.Adams is an unknown quantity at this point
Send a message via AIM to D.Adams Send a message via MSN to D.Adams
Looks good .
But i got some questions
Will the stock T25 inlet and outlet fit on this turbo?
Will you need new Oil / Water lines ? Or can you use the t25 lines ?
Whats the warranty ?
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
http://zilvia.net/f/builds-builds-on...u-city-az.html
Owner of NVS Fabrications
D.Adams is offline   Reply With Quote
Old 05-24-2010, 05:20 PM   #6
Grenade180sx
Originally Posted by s13bdafocker View Post
Looks good .
heres my engine bay.
i ran new oil feed and drain, the line itself is like $15 bucks from any line shop or contact G&J aircraft in ontario california and they will hook you up.
you could run the stock water lines but i just capped mine and ran oil only as the water lines are just meant for people who go from point A to B without letting the car cool down for 1min or 2min.
i believe the stock inlet and outlet will fit, but they come with the adapter plates as well.
Old 05-24-2010, 06:10 PM   #7
!Zar!
!Zar!'s Avatar
Originally Posted by Grenade180sx View Post
few quick facts
What size injectors were you running, 740cc?
Old 05-24-2010, 08:33 PM   #8
Grenade180sx
no sir, 550cc on 100 octane(76 street blaze) im about negative 20 percent on fuel! so i still have ALOT of room in the injectors.
Old 05-25-2010, 04:06 PM   #9
Fatboy Garage
Looks good .
the Warranty is 1 Year limited warranty(installed by ASE Tech) , you blow it we will warranty no Question ask
Thanks
Ken,S
Old 05-25-2010, 04:38 PM   #10
steve shadows
steve shadows's Avatar
what ems you using? output seems a little off
do you have graph with RPM on the axis to see what the spool is like?
Like Me on FaceBook !
Old 05-25-2010, 06:04 PM   #11
Grenade180sx
ECU with bandaid SAFC
unfortunately for some reason the RPM doesnt pick up on my car. works fine any other car but not mine. full boost with 17 degrees of timing is 4200
Old 05-25-2010, 06:28 PM   #12
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
few quick facts
Im very interested to see WHAT IT DO !!!!
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 05-25-2010, 10:11 PM   #13
steve shadows
grab a power FC for it and bring it down to our place.
We could make 350 whp easy at the same boost- and thats on a DD not a numberjet
Old 05-26-2010, 11:08 AM   #14
UNITEDMASTER
^^^^ thats the kind of numbers I thought would be there, because evo's do about the same or a lil better with the 18g or TDo6 20g. I was just contemplating fabbing on a 20g for my car(cheap oe quality) . But with this bolt on option why bother,I think this can/will be a hot setup to put you in the 350 zone without spending tons of $$$
MR JACKSON.
Old 05-31-2010, 10:02 PM   #15
Grenade180sx
ill work on grabbing a PFC soon steve, I drove the car this past thursday at Adams, and i must say its a great setup. a little laggier then a S15 but once your in boost it pulls non stop and hard!
great turbo for the cost and quality is great, glad to see godspeed stepping up there quality game and making a better product at still a great price.
Old 05-31-2010, 11:03 PM   #16
OLDSCHOOLRICER
OLDSCHOOLRICER is an unknown quantity at this point
How will this turbo do on a ka24de? Very interested in this turbo
OLDSCHOOLRICER is offline   Reply With Quote
Old 05-31-2010, 11:44 PM   #17
doug200t
doug200t's Avatar
doug200t is an unknown quantity at this point
Send a message via Yahoo to doug200t
Grab yourself a nistune board and ill give you some maps or i can reflash roms
http://www.iwannagofast.net [url]
doug200t is offline   Reply With Quote
Old 06-01-2010, 12:06 AM   #18
Grenade180sx
id say its be really fun, due to the KA's larger displacement it should spool well and will carry all the way up on teh small powerband a ka has( roughly around 55-5800rpm then the run outta breath) LOL unless ya got cams in it.
Old 06-01-2010, 12:36 AM   #19
OLDSCHOOLRICER
Thanks lot riley.
Old 06-04-2010, 06:49 PM   #20
Grenade180sx
Thanks lot riley.
no problem sir.
Old 06-07-2010, 11:00 AM   #21
2mtx12
are u using stock cams or???
Old 06-07-2010, 12:03 PM   #22
Grenade180sx
yes sir stock internals.. if i were to do cams id do 256's
Old 06-07-2010, 12:04 PM   #23
Exclusive Nights
Exclusive Nights is an unknown quantity at this point
wow... impressive and for a good price..
Exclusive Nights is offline   Reply With Quote
Old 06-07-2010, 04:11 PM   #24
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
few quick facts
so does this mean your gona start driving again?????
fcdrifter20 is offline   Reply With Quote
Old 06-07-2010, 04:23 PM   #25
Number1
Number1 is an unknown quantity at this point
very nice setup whats the name of that color?
Number1 is offline   Reply With Quote
Old 06-07-2010, 09:05 PM   #26
Grenade180sx
i call it green, but in some parts of the world its called "really green'
JUST KIDDING
no color code for it really my buddy had some extra green and we added metallic silver to it and bam.
Old 06-07-2010, 10:30 PM   #27
Z33dori
Z33dori's Avatar
what where the numbers in 4th gear? or did u only do 3rd gear pulls? if so why?
why so much timing?
Old 06-09-2010, 02:09 PM   #28
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
How's that actuator doing? Have you watched it on the dyno? I'm running a FP 20G on my SR and I had a sluggish boost curve b/c of the original actuator provided; looks like that one. With an HKS actuator, its less than a laggy turbo, even at 1 bar.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 06-11-2010, 09:27 AM   #29
ZX88
ZX88's Avatar
what engine managment should i use for a set up like this. nistune, aem, power fc?
IM PONDERING WITH
18g
fmic
3 inch exhaut
walbro
nismo fpr
750cc injectors ???/
bc stage 2 cams
springs
stainless oil lines
( engine managment?)
Old 06-11-2010, 10:53 AM   #30
Fatboy Garage
IM PONDERING WITH
18g
fmic
3 inch exhaut
walbro
nismo fpr
bc stage 2 cams
springs
stainless oil lines
Power FC
Thanks
Ken,S
