![]() Join Date: Aug 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
![]() WTF thermostat! I did an emissions removal a little bit ago and while i was taking off the manifold I just thought I'd replace the thermo too. Well it started overheating QUICK once i threw everything back together. I took out the thermo and ran it, Temps were fine system bleed out nicely. So I got a thermo from Nissan Installed it and BAM! overheating, the thermo refuses to open, nothing coming out of the blurp hole, hot air, bleeding the system correctly, losened the upper heater core hose. NOTHING the damn coolant WONT FLOW. This is really starting to piss me off. I did this a little bit ago with no air problems. Im thinking there is only air hitting the thermo and not coolant?! HOw do i get the damn coolant to flow to the thermo?! Any help would be appreciated, tips & tricks??
#6 |
![]() Join Date: Sep 2008
i would use a radiator testor thing.just replaces where your rad cap goes, then while the fluid is in start to pump the radiator with pressure and see how high it gets.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
#7 |
![]() Join Date: Jul 2009
a way u can test thermo is to boil some water on the stove and throw in the thermo and see if it opens, if not then theres ur problem. if it does open, then ur SOL lol
#8 |
![]() Join Date: Apr 2008
can it be put in backwards?
https://www.linkedin.com/in/hassanbakar |
