Old 05-27-2010, 09:55 PM   #1
t.vo408
t.vo408 is an unknown quantity at this point
Unhappy sr20det Swap Bogging out after startup, ok after a little throttle???
So I just finished the swap and it ran fine for the first day. The second day, right after cranking it starts fine but then idle drops and finally stalls. But it will be OK if I keep the rpms at about 1500 for about 10-15 seconds its fine and runs ok. Sometimes at lights the idle will wander from about 1000-600 rpms. If I turn the motor off and start it right after the problem occurs again, will stall if I don't keep the revs up for a little.
Pretty weird that it runs fine after keeping revs up, but the problem immediately occurs again if I turn the car off and back on. Any ideas? Also what should idle be?
t.vo408 is offline   Reply With Quote
Old 05-27-2010, 11:32 PM   #2
t.vo408
I'm thinking it might be a vacuum leak, would that cause it? I opened the hood and can hear a slight hissing noise coming from the turbo side. Also when I let off throttle vacuum does to -20mmhg and then rises up to -15 so both those lead to a leak. So I'll investigate tomorrow when there's some light out.
Old 05-27-2010, 11:41 PM   #3
ddf2006
ddf2006's Avatar
ddf2006 is an unknown quantity at this point
for sure it is ur mass air flow sensor
this happined to my ka
randomly wen im driving it will bog and go slow then speed up
and wen i came to a stop sometimes the idle will jump up and down and turn off
for sure replace it and ur good
ddf2006 is offline   Reply With Quote
Old 05-28-2010, 12:03 AM   #4
t.vo408
Sweet, I'm gonna try to fix the vacuum leak tomorrow, then clean the maf (spray carb cleaner on it or something) and spray some carb cleaner into the IACV tube near the tb and see what happens.
I just tried starting it up and it started no problem without dieing..... So it might also be a temperature thing, it was really hot earlier today. My gauge pretty much reads hot all the time like maximum, but that also happened when I had a KA so I'm not really sure whats going on there. Running stock sr20 rad and clutch fan.
Old 05-28-2010, 09:43 PM   #5
dopplganger1
dopplganger1 is an unknown quantity at this point
do not use carb carb cleaner on your maf they have a special spray for it
dopplganger1 is offline   Reply With Quote
Old 05-28-2010, 10:25 PM   #6
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
check your coolant temp sensor
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 05-29-2010, 01:36 AM   #7
t.vo408
I am like 90% sure this is a vacuum leak... But my temp gauge is still jacked. By coolant temp do you mean this one?
FAE KA/SR Dash Gauge Temperature Sensor S13 Chassis
Or the one that talks to the ecu?
Old 05-29-2010, 07:06 AM   #8
lazysk8er2
lazysk8er2's Avatar
the one going into the motor.
