![]() Join Date: Aug 2008
Trader Rating: (43)
![]() Feedback Score: 43 reviews
![]() I have a ka24de that came off a 97 240sx i dropped it in my 91 240sx i kept the same harness i just changed the intake manifol it ran fine for about 7 months n now its acting up ... when ever i floor it the car will bog out at like 45k rpm it feel like if i would b at red line n it dosnt wanna move it just starts jerking back n fwd n also wen ever i floor it the temparature gauge shoots all the way down like of the car would b cold and the check engine light comes on but since im driving wen it happens it always shuts off wuth in accupple of seconds ... and its been runing for a wile n i turn it off n try to turn it back on it wont turn on i have to keep trying to popstart it n it only work sometimes i usually have to wait for a wile before i can turn it on n wen it does come on it shoots a big cloud of black smoke n it smells like gas n it sounds like a suburu at idle for a little wile then it sounds normal again ...... some one pls help mee !!
mike! ![]() |
Just helped a friend with this. It may be your Throttle Position Sensor, it may not be plugged in or faulty or set incorrectly.
It also could be one or more of your injectors took a shit. You would need to remove the harness plugs that plugs into each injector, and use a Multimeter to check the injectors to see if they are 11 ohms (which is good) and 0 ohms is bad injectors. Surbaru = Bad injector(s) or Maf Jerking = TPS |
#10 |
![]() Join Date: May 2009
![]() Feedback Score: 11 reviews
Let me help you out here
hit up my buddie Juan he's really legit working on 240's here's his account on zilvia hit him up? http://zilvia.net/f/members/bardabe.html
http://www.iwannagofast.net/ FOR SALE: DOHC maf, KA down pipe and SR A/C pump like new pm me for price. |
#13 |
im sure its your injectors. as the car is running at idle, try removing each spark plug one at a time and see if there is any difference in idle. if not, put it back and try the next. it will help you eliminate part of the possibilities. to me, it sounds like your injectors, one of them either maybe going out or the o-rings are just going bad. so try the injectors and report back here to help future zilvians.!
#18 |
A while back my car jerked the way you describe. When I went under the hood i rep'd the MAF and actually found that my Spark Plug wells had water in them(1) and the ones that didn't have water in them had spark plug wires not seating properly(2)
While this might not be the problem, its definitely something worth checking out :O gl |
#21 |
![]() Join Date: Aug 2004
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
cts=coolant temperature sensor
the car would bog and turn off,run really hot and turn off then had to wait like 20 mins for it to think its cool enuff to run and also ran really rich black smoke would shoot out
Red Rocket |
#23 |
Trader Rating: (44)
im not saying thats it im just sayin its a cheap start and if its not it hey u dont gotta worry bout it down the line cuz u just put in a new part
Red Rocket |
#24 |
![]() Join Date: Sep 2008
Its hard to find someone that will actually go and help you fix your car. especially for free... Might as well take it to a shop and see how much it costs.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
