Old 06-16-2010, 09:01 AM   #1
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
Running DUMB rich...need suggestions
UPDATED
ka24de built bottom
E-Mance Tune (never had a prob so ppl dont start)
370cc (now running 550cc)
GTi-R t28/ with s14 t28 comp housing (12psi)
walbro fuel pump
FMIC
3" Turbo Back
SAFC II
Ok, So for some reason my car is now running dumb rich....i mean like 10 afr through the whole rpm range. The idle is choppy from running rich i suppose and at times the idle will be smooth but still at 10 afr, I had to use my SAFC and changed the settings to -10/-20 to get it to drive safely up and down the road to see how it runs.!?!?
This is random, all i did was switch out my solid motor mounts to stock and then wanted to go for a drive and its running rich....ANY INPUT/SUGGESTIONS ARE APPRECIATED
Things I've done so far:
- Checked for boost leaks, took bumper off and inspected intercooler, piping, and couplers for defects.
- Timing is dead on along with cam timing
- Switched to stock ecu and still the same thing.
- Checked all grounds
- Checked z32 MAF wiring, even put my stock MAF back on, changed settings with SAFC and still the same thing
- Put in new spark plugs and still did the same thing
- Checked for leaky injectors; ie - checked o-rings and pulled fuel rail and turned key to ON
- Replaced Coolant Temp Sensor (New)
- New injectors
- Adjustable Fuel Pressure Regulator (afpr)
*Narrowed it down to being electical...ECU should go into "fail-safe" mode but doesnt. ie; disconnecting the maf the car will not rev above 2.5k or 3k.....
* Popped open my ecu and found that pin 17 (maf) is fried on the board. But switching back to a stock one didnt make much of a difference either...hmmmm..more electrical gremlins
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 06-16-2010, 09:24 AM   #2
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
need more details on your setup. are you running a walbro fuel pump. and if you are are you running an adjustable fuel pressure regulator. if you arent running an fpr you WILL run pretty rich. also you said nothing about what tune you were running. are you running an ecu that is tuned for 370s? -10 to 20 is not enough compensation for that. stock is 270 yours are 370. 100cc difference. just to give you an idea. i tuned an sr with s15 480s and a walbro with stock fpr. we had to pull almost 50% out of the fuel. and we were running 11.5 afrs which is where you wanna be under boost. if the fuel pressure were right it would nearly be as bad. my next concern is your o rings. its pretty easy to mess up the o rings on side feed injectors. buddy of mine did a ka-t with 370s and was having this probably. o rings were at fault and never got it right. blew a head gasket a couple days later. you gotta be careful and gotta know what your doing. some more details on your setup would help. and also im assuming your running a wideband. what kind are you using?
ch1873857 is offline   Reply With Quote
Old 06-16-2010, 09:45 AM   #3
ATLspeed
ATLspeed's Avatar
ka24de built bottom
370cc
z32 Maf
walbro fuel pump
FMIC
3" Turbo Back
AEM Wideband
SAFC 2 (for fine tuning and if i change up injectors)
Im not running an afp regulator, I planned on getting one if i ever switch to top feed. Ive been running this set up for a year (at 10psi) and never had a prob. Im just really not sure whats going on.
95 Supra Turbo
Old 06-16-2010, 10:10 AM   #4
ch1873857
if this just happened out of nowhere id start with the o rings personally
Old 06-16-2010, 10:43 AM   #5
ATLspeed
ATLspeed's Avatar
i checked rings as well but they were ok
**The car is running like it should again, I had the battery disconnected overnight and hooked it back up this morning and its running like it should again. not sure what the problem was still tho
Thanks for the input/help tho ch1873857
95 Supra Turbo
Old 06-16-2010, 11:24 AM   #6
Sileighty_85
Sileighty_85's Avatar
Did you check/ Replace the Coolant Temp Sensor (CTS)?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-16-2010, 11:45 AM   #7
ch1873857
so resetting the ecu fixed it? weird.. but cool!
Old 06-17-2010, 01:24 PM   #8
ATLspeed
ATLspeed's Avatar
ok so the sucker is still doing it, it started back running rich again after a couple runs up and down the street.
- CTS i may have to check, isn't there a way to check to see if your temp sensor is good or not by using a paperclip and jumping the coolant harness?
95 Supra Turbo
Old 06-17-2010, 01:31 PM   #9
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
just throwing it out there, but have you checked the ecu for codes?
VNG704 is offline   Reply With Quote
Old 06-17-2010, 01:36 PM   #10
ATLspeed
ATLspeed's Avatar
just pulled them again after resetting and i got 13 and 21
13 - Coolant Temp Circuit/Sensor
21 - Ignition signal in the primary circuit is not being entered to the ECU during cranking or tuning
*Im not sure if i caused code 13 myself by jumping the harness with a paper clip but i shall buy it and report back
95 Supra Turbo
Old 06-18-2010, 03:17 PM   #11
bb4_96
bb4_96 is an unknown quantity at this point
i suggest you get an ls
bb4_96 is offline   Reply With Quote
Old 06-18-2010, 06:23 PM   #12
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
ugh, bb quit posting that stupid shit in the threads >.<
Did you actually test the cts? There should be a resistance rating for it when the engine is at temp, pull it up on your corresponding fsm.
nismoracingsx is offline   Reply With Quote
Old 06-18-2010, 07:36 PM   #13
ATLspeed
ATLspeed's Avatar
well i swapped out the cts for a new one and its still running rich were its to the point that its hard to stay on.
*I have a drift/grip event on july 3rd and this is starting to hurt my feelings. Im too the point were Im thinking about buying new injectors (550cc-750cc) to see if that solves my problem (yes i kno its a dumb reason)
95 Supra Turbo
Old 06-18-2010, 08:53 PM   #14
Sileighty_85
one thing I noticed
You said when you checked the injectors you put it to ACC, That wrong you need to put it to "ON" so that the fuel pump kicks on.
後輪駆動車1番
1986 SR86 - 200ish
Old 06-18-2010, 09:53 PM   #15
ATLspeed
ATLspeed's Avatar
my bad i meant to say i put it to ON so the fuel pump would kick on and add pressure. had a bottle on the tip of the injectors along with napkins to see if any leaking came about
95 Supra Turbo
Old 06-20-2010, 03:17 PM   #16
jbballa9876
jbballa9876 is an unknown quantity at this point
Did you check the filament on the MAF? whats good with the ignition signal though??
jbballa9876 is offline   Reply With Quote
Old 06-20-2010, 04:02 PM   #17
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
O2 sensor?
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 06-24-2010, 12:31 PM   #18
ATLspeed
ATLspeed's Avatar
I'm starting to narrow it down to fuel pump (even tho its only 2yrs old walbro) or bad fuel pressure regulator.
When i unplug the fuel pump fuse it idles smoother..but it still runs rich and i cant give it gas
- the maf screen/sensor is ok, I'm able to unplug the maf and the car runs the same. Doesn't go past 3k like it should while unplugged
- I don't run an o2 sensor with my ecu tune
95 Supra Turbo
Old 06-25-2010, 07:47 AM   #19
ch1873857
it still runs rich even then the fuel pump is unhooked? and of course you cant give it gas. it sounds like injector o-rings still. i dont know man.
Old 06-25-2010, 08:49 AM   #20
ATLspeed
ATLspeed's Avatar
Thats the thing, I would have thought it would have been injector o-rings to but I have even install a new set of injectors. So I'm believe fuel pressure is my culprit.
To my understanding and searching if there is too much fuel pressure (or bad fpr) it will cause the motor to run rich or flood. Also if i build up fuel pressure and pull the fuse it will start and run smoother because the fuel pressure is dropping as the injectors get rid of the fuel in the lines.
95 Supra Turbo
Old 06-25-2010, 09:00 AM   #21
clain
clain is an unknown quantity at this point
You changed the single wire CTS for the temp gauge or the CTS that has 2 wires going to the ecu?
clain is offline   Reply With Quote
Old 06-25-2010, 11:22 AM   #22
ATLspeed
ATLspeed's Avatar
The CTS for the ecu (2 wire)
95 Supra Turbo
Old 06-25-2010, 12:55 PM   #23
DeatschWerks
DeatschWerks's Avatar
DeatschWerks is making a name for him/her selfDeatschWerks is making a name for him/her self
It weird how problems show themselves after a completely unrelated modification or change.
You didn't unhook any grounds to get to the mounts and forget to put them back on? Shot in the dark and I'm probably way off the mark...but I've curved bullets before.
Chris @ DeatschWerks.com
Fueling Your Passion for Performance!
DeatschWerks is offline   Reply With Quote
Old 06-25-2010, 02:11 PM   #24
younghatchowner
younghatchowner is an unknown quantity at this point
pull ur injector out..the seals are bad..hapened to my car..or your injectors are having a stiffy..its your injectors..promise
younghatchowner is offline   Reply With Quote
Old 06-28-2010, 11:56 AM   #25
blackoutt
blackoutt's Avatar
blackoutt is an unknown quantity at this point
Any updates on this? I'm having a similar problem with similar setup and done similar checks. Haven't checked FPR pressures though.
blackoutt is offline   Reply With Quote
Old 06-29-2010, 01:51 AM   #26
greenzenki86
greenzenki86's Avatar
greenzenki86 is an unknown quantity at this point
yeah from the sounds of it id check the injectors too, pull them all off and do each one individually. I had a similar issue with my KA when I first got it.
greenzenki86 is offline   Reply With Quote
