Old 06-20-2010, 12:28 AM   #1
mrbells
mrbells's Avatar
mrbells is an unknown quantity at this point
AVCR/SAFC sensor checks different
So i was working on getting my throttle position % the same on the AVCR and SAFC. I got them both at 100% with the tps voltage from throttle body at .49. It is recommended .45 to .50 with closed throttle. The problem i am having is my avcr and safc read different throttle voltage. My Avcr reads .356 and Safc reads .36/.37 Now that should be the same as my TPS reading correct!?
I do not have my AVCR/SAFC grounds ran together however, the power wires are connected together to the ecu. The throttle wire are the same for the avcr and safc but i separated the two wires when connecting to the throttle wire to ecu.
Any suggestions? Thanks
mrbells is offline   Reply With Quote
