Old 06-23-2010, 11:07 AM   #1
S14mc
S14mc is an unknown quantity at this point
Bad valve seals = Bad O2 Sensor
The other day I noticed oil leaking from the exhaust manifold port (cylinder #1). It looks like its coming from a worn out/bad exhaust valve seal. Ran a compression and leakdown test, 147-150 across the board and 4%,7%, 7% and 25% on cylinder #1. Spark plugs confirm no oil being burnt in combustion chamber.
My question is this - Will it be okay to drive with my motor (cylinder #1) in this condition? Is the valve seal leak affecting my O2 Sensor erroneously changing the lean or rich reading? Just a guess, but it feels as though this may be the reason why my motor doesn't pull as hard as it used to. When my car is warmed up and goes closed loop it feels my car loses 50% of it power.
Any input would be great!
Thx
Jon
S14mc is offline   Reply With Quote
Old 06-23-2010, 11:09 AM   #2
Deviousjet
Deviousjet is an unknown quantity at this point
TTT having the same issue but now my car is sputtering!!!
Deviousjet is offline   Reply With Quote
Old 06-23-2010, 11:21 AM   #3
S14mc
Could be your maf? Have you checked your ignition/coils?
Old 06-23-2010, 11:23 AM   #4
Deviousjet
Yup swapped maf and replaced coil last year. The car sputters at idle. then when I turn the ac on the idle is fine, no missing or anything. Then turn the ac off and the car goes back to sputtering
Old 06-23-2010, 11:36 AM   #5
S14mc
Battery + Charging system??? Did you replace your O2 Sensor?
Old 06-23-2010, 11:37 AM   #6
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
s14mc, as far as I know, bad valve seals won't hurt performance. If anything, not 50% as you said.
deviousjet, I would check coil for good connection. Have you changed sparkplugs? I know a sparkplug with wrong gapping would cause sputter at idle. I can tell you that the ac being on raises the idle that's why the sputter is going away. A bandaid solution, but you can raise the idle by adjusting the IACV.
VNG704 is offline   Reply With Quote
Old 06-23-2010, 11:51 AM   #7
Deviousjet
recently changed spark plugs, pulled them out and spark plug electrode#4 was covered in soot or oil I'm guessing. ALso just recently replaced the alternator and starter. Running out of things to replace. Looking like the egr sensor possibly?
Old 06-23-2010, 11:56 AM   #8
VNG704
VNG704's Avatar
I asked about the sparkplug replacement because some people just drop them in without checking the gap. /threadjack.
Old 06-23-2010, 12:16 PM   #9
yabeet
yabeet's Avatar
yabeet is an unknown quantity at this point
If anything you will have crud on your valves [from oil dripping down them constantly] in cyl 1 that is preventing them from sealing good when closed.
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’
Jeremy Clarkson on Automatics
yabeet is offline   Reply With Quote
Old 06-23-2010, 12:21 PM   #10
hiimgreg
hiimgreg's Avatar
hiimgreg is an unknown quantity at this point
did you do a leak down test?
do all your valves seal?
hiimgreg is offline   Reply With Quote
Old 06-23-2010, 12:44 PM   #11
S14mc
I did do a leak down test. All percentage were good except 25% on cylinder #1. I'm now thinking, possibly because a worn valve seal, oil deposits built up where the valve sits, compromising the valve to fully close. Does this warrant pulling my head and replacing seats, valves, and guides? I do have a set of BC cams laying around. Maybe its time to put those in as well. So little time, too much to do.
Thx for your input so far guys.
Old 06-23-2010, 07:46 PM   #12
rex2sx
rex2sx's Avatar
rex2sx is an unknown quantity at this point
Leakdown Test IS NOT for oil, its for compression leaks. Tell me, if your valve SEATS are sealing like they are supposed to. While the valves are CLOSED doing a leakdown test, how are bad umbrella (aka valve) seals going to show up? They ARE NOT
BTW it said that 20% cylinder leakage is still ok. Read the gauge, 20% is still green, anyway. I wouldnt bee too worried until it passes 30+
Honestly, i think they is something called a valve guide test but other than that, without tearing the motor apart, its hard to daig leaking valve seals.
Also, how is your 02 sensor responding? Are the PIDs jumping back on forth showing rich/lean?
Oil does ruin your 02 though..So if its not switching like it should be..it might need to be replaced after the leak is fixed
SR20DET RDTOP Cylinder Head FS
rex2sx is offline   Reply With Quote
Old 06-24-2010, 07:28 AM   #13
VNG704
VNG704's Avatar
How is your o2 mounted? If it's not at the bottom of piping, it might not even be affected by the oil. May unscrew to check for crud on the o2?
Old 06-24-2010, 11:58 AM   #14
S14mc
Good point. I'll see if I can borrow a wideband.
Old 06-24-2010, 11:59 AM   #15
S14mc
I have a bottom mount, so its right after the turbo on the o2 housing.
Old 06-24-2010, 02:46 PM   #16
rex2sx
rex2sx's Avatar
You dont necessarily need a wideband. Just test your factory 02 sensor with a Digit mulit meter, volt meter, or watch the PIDs on a scan tool.
Old 06-24-2010, 03:58 PM   #17
S14mc
I see. That's right. Should I be seeing oscillation between .9 to .2 volts? Or should it be at a particular voltage?
Old 06-24-2010, 04:23 PM   #18
rex2sx
rex2sx's Avatar
Pre cat..should "bounce" back and forth, like you said
Post cat.should maintain a more consistent reading with minor switching
Old 06-24-2010, 04:29 PM   #19
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
o2 has nothing to do with you loosing power, over 60% throttle ECU runs open loop and ignores any o2 readings.
Check your fuel pressure, ECT sens, and TPS.
Mechanical stuff would be a clogged cat, worn cam lobes, non sealing valve seats. Check with google on how to test for any of these if you need info.
Hashiriya415 is offline   Reply With Quote
Old 06-24-2010, 05:05 PM   #20
rex2sx
rex2sx's Avatar
Do you know how the ECU reads WOT. At +4.9volt. At WOT your car is not using feedback form the O2. So if your ECU is reading WOT at only 60% of throttle, looks like YOU have a problem. 02 sensor feedback is not used either at WOT or cold starts
02 does cause loss in power, poor gas milage, and a horrible idle among other things. What makes you think it doesnt??
Old 06-24-2010, 07:35 PM   #21
Hashiriya415
Trader Rating: (22)
I don't have an o2 on both my tuned cars and my bike that run OPEN loop all time.
No power loss, better gas mileage since it runs leaner then factory, normal idle. Makes me think something wrong with your vehicle.
You want to be controlled by the government keep your o2 with factory tune for an efficient 14.7 clean burning combustion chamber and proper working cat. That's what your o2 is good for, making you stay in the 14.7 for maximum cat efficiency and clean air-fuel burning.
Why do bikes not have an o2, except Cali most do?
Old 06-24-2010, 10:07 PM   #22
rex2sx
rex2sx's Avatar
Ok..Where do i start...Your explanation was still not correct. Plus, you never stated you had a tuned vehicle in the beginning. How do you know he has a tuned ECU? You disbale 02 sensor feedback on TUNED vehicles..Some ECUs need to see feedback from an 02 to work properly. Im not sure if it is this way for nissans becuase i have never tuned on them, i will admit. From an average consumer standpoint (untuned), yes; gas mileage will decrease along with power and other problems.
Plz show me a bike thats not car'bd that does not run an 02 sensor. This is interesting info.
Old 06-24-2010, 10:17 PM   #23
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
If they were seals, you'd have a puff of blue smoke on initial start up, size of smoke depends on how worn they are. Let the car sit one night and on morning start, look for smoke. You wouldn't have an external visual leak of oil outside the engine. Not you problem.
What you're dealing with, high leak and rough runnng, low fuel mileage, no power, sounds like you have a burnt valve in number one. Do a leak down test again and listen for where the air is escaping. If you hear it in the exhaust, burnt exhaust valve. If you hear it in the intake, burned I take valve (highly unlikely since these run cooler than the exhaust valves). Lastly, if you hear air leaking in the engine (like through the oil fill cap), you have bad rings. Now, with this, you need to take the cylinder head off and regrind the valves at a machine shop or re-ring the pistons (depending on where the leak is).
Basically, you're talking about valve seats, not seals. The seats will cause sensor malfunction due to incomplete burn; fouling o2 sensors and such.
Pacman is offline   Reply With Quote
Old 06-24-2010, 10:35 PM   #24
rex2sx
rex2sx's Avatar
the worst thing he got was 25%, which is still "good", well it is according to the gauge. So i dont think burned valves have that low of a percentage, but maybe?? I simply brought up the other symptoms dealing with an 02 senor so he might watch them to see if he experiences this, becuase the OP was worried about his 02. For all we know it could be fine.
OP: What engine do you have? and what modifications?
Old 06-25-2010, 10:42 AM   #25
S14mc
Its an S13 Blacktop. I'm running a JWT tuned ecu. Program is for 50# injs. and Z32 maf. Actually, my car idles and drives fine, with the exception of a noticeable power loss. No noticeable smoke when the car is fully warmed up, accel or decel. Only thing is I can "smell" the burnt oil when I pull up to a stop. That's why I was thinking that possibly the leaking oil may cause a disruption with the o2 sensor, hence affecting performance. I had a spare o2 sensor and tried that out but same result. The power loss is only noticeable once the car is fully warmed up and after about more or less 20 mins on the freeway. Should I try running without an o2 just to see if there's a difference?
Old 06-25-2010, 12:14 PM   #26
VNG704
VNG704's Avatar
The burnt oil smell is the oil on the exh mani. Was it leaking out of the exh mani port 1 or on it? Can you see where the oil is leaking from? could be valve cover gasket, could be from that "T" for blow-by off the crankcase, loose hose.
The power loss could be anything. It could be stuck wastegate? I mean, I don't think the o2 has anything to do with your prob. I'd look elsewhere.
Old 06-25-2010, 12:27 PM   #27
S14mc
Thx. The oil is coming from inside exhaust port #1. I'm assuming it has be a worn valve seal or blow-by.
