![]() managed to take off the rear links to get the bushings and new RUCA installed, not successful no matter how hard i tried. i have a torque wrench, set it to max, and it maxed out.
should i take all the troubles to rent a air gun (impact wrench) with compressor? or any recommened lubicator will help me? thanks |
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
liquid wrench or pb blaster works
get a HUUUUGE breaker bar (or add extension to a wrench/breaker bar) and go at it ![]() |
Werd. get a breaker bar, add your jack handle to the end as a cheater bar. Those bolts are torqued down HARD, especially on an aging 240!
It's not a good idea to use your torque wrench as a breaker bar... you'll mess up the torque setting. This is especially critical on a click-type torque wrench where you can't see if it's still accurate or adjust it back to zero if it isn't. |
WOW addicted
![]() Join Date: Dec 2001
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
I think I understand.. but just to clarify..
Are u having trouble removing: 1. Bolts from links where they attach to the rear upright? 2. Bolts that attach links to chassis?
#7 |
ok rear links to the subframe then.
oh yah i need to unblot the rear subframe too get the spacers installed. Argh i cant remove those blots too. actually i couldnt remove most of the blots if it's under the car surrounded with dirt. do i really need a air gun? what are pb blaster and breaker bars? |
#8 |
WTF are you talign about?
rear links? NO REAR LINKS FOR SUBFRAME BOLTS TO INSTALL SUBFRAME SPACERS!!!! whatever it is..do what i said above. my first post. if you cant do it, take it to a shop. simple as that. |
#9 |
i want to install subframe spacers AND bushings for the rear links AND new rear upper arm. oh well... and front sway bar and t/c rod...
but i couldnt take any of these bolts out... ok i will try |
#17 |
![]() Join Date: Mar 2002
haha lightweights. Yeah lube it up with some PB Blaster/WD-40, tap the spot with a wrench to break up the oxidation, and let it sit for a little bit before you try to take it apart, give it a few minutes, or even hours if it's really bad. Breaker bar is key.
#18 |
![]() Join Date: Sep 2001
not to be redundant, but as was said above spray some wd40 on it and let it soak awhile.
And while a breaker bar is best, if you're low on cash or just want a cheaper way, you can get a length of pipe and slide it over the handle of the largest wrench you have - essentially making the handle longer, thus giving you more leverage and if all else fails, call the biggest friend you have, and have him give it a try.
White 98 s14 |
