Old 07-10-2010, 09:50 PM   #1
s13ways
s13ways is an unknown quantity at this point
S13 Ka24de "click" (WONT START)
I know, One more of these storys. Here's the info. S13 ka24de automatic. Started two day's ago and drove no problem. No it just clicks.
-took out the starter and had it bench tested. (passed flying colors and even
looks brand new still)
-Battery and connections are good (dash lights stay on when I try to turn over)
My three questions
1.)Automatics don't have a starter relay correct?
2.)Thats what the neutral safety switch is for correct?
3.)Would car start with a faulty non working neutral safety switch?
s13ways is offline   Reply With Quote
Old 07-11-2010, 12:35 PM   #2
kb1991
kb1991 is an unknown quantity at this point
alternator...
kb1991 is offline   Reply With Quote
Old 07-11-2010, 01:01 PM   #3
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
is your car in park...
WheelsDirty
Old 07-11-2010, 01:26 PM   #4
keistyle
keistyle's Avatar
keistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond reputekeistyle has a reputation beyond repute
Send a message via AIM to keistyle
have you tried starting it in neutral.
It might be the relay.
Tacoheroi.com
keistyle is offline   Reply With Quote
Old 07-11-2010, 01:28 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
It is almost certainly the ignition switch. That's like THE most common 240sx problem ever. The crimps on the switch housing come loose and the switch loses connection on the inside. Replace the ignition switch, don't argue...
Old 07-11-2010, 02:01 PM   #6
s13ways
Car is in park! And tried Neutral
If it was altenator it would still start. Correct?
I will check the switch. Why would my starter go "click" if the switch is not plugged in? Not getting enough volts?
Old 07-11-2010, 02:31 PM   #7
racepar1
racepar1's Avatar
Don't check it. Do what I said and go buy a new one. It loses connection inside the switch and doesn't send enough voltage. You won't be able to see anything wrong unless you know what to look for. You obviously don't know what to look for.
Old 07-11-2010, 02:40 PM   #8
r20crazy
r20crazy's Avatar
Trader Rating: (41)
r20crazy is an unknown quantity at this point
Feedback Score: 41 reviews
I'm ASSuming you had the battery load tested already? just because lights are on/don't dim doesnt mean battery is good. it may have a surface charge but not the deep charge needed to turn car over.
r20crazy is offline   Reply With Quote
Old 07-11-2010, 03:13 PM   #9
s13newb
s13newb's Avatar
s13newb is an unknown quantity at this point
Send a message via AIM to s13newb
Check the batt with a volt meter have someone try to turn the motor if volts go under 9.5 -/+ .2 then batt aint good and dun take it to autozone they just check if it holds a charge.
s13newb is offline   Reply With Quote
Old 07-11-2010, 03:15 PM   #10
s13newb
s13newb's Avatar
Oh yea dun buy parts dat you dun need test dont guess ..
Old 07-11-2010, 03:20 PM   #11
racepar1
racepar1's Avatar
Anyone who works on cars for a living raise your hand...
Oh, look I'm the only one with my hand up...
There's no point to testing, I KNOW for a FACT what it is. I've seen this a hundred times. I don't even bother to check stuff anymore when I see this problem, I just sell the customer an ignition switch. I haven't been wrong yet...
This is seriously one of the top two 240 problems ever...
Old 07-11-2010, 03:38 PM   #12
s13ways
Battery is good. I put in my other 240 and started it right up no problem. I will try switch the ignition switch with my other 240 and see if that works. It's just the whole key part with pigtail correct. Wouldn't it not even go "click" if it was the ignition switch?
Really aprriciate the help. But does anyone know if automatics have a starter relay because mine doesn't but my 5spd does. wierd.
Old 07-11-2010, 06:34 PM   #13
racepar1
racepar1's Avatar
I'm going to stop helping you if you don't listen to me...
You just need the electrical part, no key or anything. It screws onto the back of the key cylinder with two littloe screws...
Old 07-12-2010, 06:55 PM   #14
s13newb
s13newb's Avatar
Didnt mean to hurt ur feelings man . My bad just trying to help
Old 07-12-2010, 09:32 PM   #15
tommytwo40hands
tommytwo40hands is an unknown quantity at this point
http://zilvia.net/f/tech-talk/114304...-location.html
tommytwo40hands is offline   Reply With Quote
Old 07-12-2010, 10:07 PM   #16
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
not gonna lie racepar1 is right lol i have the same problem. the old owner thought it was the starter and changed it twice. its an s13 auto coup with 76k miles hahaha
i came along bought the car for dirt cheap and drove it away lol
change the switch.
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 07-12-2010, 11:07 PM   #17
doomviillain
doomviillain's Avatar
doomviillain is an unknown quantity at this point
Send a message via Yahoo to doomviillain
stop trouble shooting, its the ignition switch my friends automatic had the same problem. take racepar1's advice dood
doomviillain is offline   Reply With Quote
Old 07-12-2010, 11:18 PM   #18
doomviillain
backyard mechanic
Old 07-13-2010, 01:07 AM   #19
s13ways
Well I put another starter I had laying around in today and it starts right up. I wonder if the switch is staying on like that post Starter relay location .( Link doesn't work). I guess we will see how this starter holds up.
Old 07-13-2010, 10:35 PM   #20
s13ways
so car starts right up today. Time will tell if its ignition switch
Old 07-14-2010, 10:13 AM   #21
racepar1
racepar1's Avatar
You have no idea how many times we have all heard this before...
Good luck...
Old 07-14-2010, 11:04 AM   #22
240sx123$
240sx123$ is an unknown quantity at this point
lol, If people dont wanna listen, you cant force them to.
He'll replace the switch when hes replaced everything else first.
240sx123$ is offline   Reply With Quote
Old 07-14-2010, 11:40 AM   #23
heavenboundkevin
heavenboundkevin's Avatar
heavenboundkevin is an unknown quantity at this point
10 bucks says he replaced the switch, and just said it was the starter to not sound like a dumbass for not listening.
Originally Posted by rat240 View Post
sick bro .... hella jdm foshow i love haters
heavenboundkevin is offline   Reply With Quote
Old 07-14-2010, 01:31 PM   #24
ThomasJamal
ThomasJamal is making his/her stupidity well-knownThomasJamal is making his/her stupidity well-knownThomasJamal is making his/her stupidity well-known
So I'm having the same problem and I'm wondering, just for the hell of it, if there is any way to test the switch? Since I'm stuck at home for about 2 more hours (autozone is a long walk) I figure I might as well test the switch so I know for sure when I go to the store.
ThomasJamal is offline   Reply With Quote
Old 07-14-2010, 01:36 PM   #25
creyes13491
creyes13491's Avatar
Trader Rating: (30)
creyes13491 is on a distinguished road
Feedback Score: 30 reviews
YUPP! respar1 is right. i couldnt agree more. cuz my car has the same problem. its the ignition switch.
creyes13491 is offline   Reply With Quote
Old 07-14-2010, 01:46 PM   #26
ThomasJamal
I have a manual, by the way. Is this a problem mostly for autos?
Old 07-14-2010, 03:52 PM   #27
racepar1
racepar1's Avatar
You check the voltage on the start signal wire. It should be about battery voltage when you crank the engine.
Old 07-15-2010, 01:56 AM   #28
s13ways
Haha interweb thug!
I guess we will see if it was the switch. It's been two days and lots of luck so far. I only start it to get other things in the back yard. Just trying to sell it but want it fixed before she goes. Thanks for all the help. By the way not one person answered where the starter realy is for automatics. My guess is they don't have them.
Old 07-15-2010, 01:59 AM   #29
chetacheese
chetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of light
Send a message via AIM to chetacheese
i have this same issue and ill be another person to have this issue. but ill try racepar1's solution and ill put in my 2 cents.
chetacheese is offline   Reply With Quote
Old 07-15-2010, 02:04 AM   #30
240sxftww
240sxftww is an unknown quantity at this point
id go with the relay or the ignition switch ..
happens at lot on s13s..
is your car lowered? check your harness.
240sxftww is offline   Reply With Quote
