Old 07-12-2010, 05:33 PM   #1
Dyl510
Dyl510 is an unknown quantity at this point
SR20DET No Boost?
Don't seem to have any boost..... For one I haven't seen my wastegate move an inch since it's been running/revving up
Moreover, I have a vacuum line connected to my Fuel Pressure Reg. which is supposed to up the fuel pressure under boost... and the fuel pressure does nothing, if anything the fuel pressure drops slightly after revving.
I'd figure so long as the exhaust is spinning the damn turbo you would get some sort of boost when you hit the gas, but I can't even seem to get the thing to spool up!
Any help is appreciated thanks guys.
Dyl510 is offline   Reply With Quote
Old 07-12-2010, 05:57 PM   #2
Sileighty_85
Sileighty_85's Avatar
Nope you have to put a load on the engine to build boost, free reving wont
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-13-2010, 09:17 AM   #3
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
^ well those tiny T25's will make something; at least enough to blow off...
make a charge system pressure tester and see if you have any leaks... Do you have a boost/vacuum gauge?
you should try and provide as much information as possible when asking for help...
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 07-23-2010, 02:27 AM   #4
Doom
Doom's Avatar
Doom is an unknown quantity at this point
Yeah, i have the same problem, so free revving wont work. So will the boost work if i go a certain speed? because i tried around the block and it still wont boost. should i try the freeway?
Doom is offline   Reply With Quote
Old 07-23-2010, 02:34 AM   #5
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
do u have a boost gauge hooked up? If so whats your vacum pressure at? Also If the wastegate Isn't hooked up to a vaccum line then your gonna boost ALOT! Lol. So don't try to not run a line to the actuator
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 07-23-2010, 02:54 AM   #6
Doom
Doom's Avatar
well actually it is my friends car, there is a boost gauge, and i dont really know what the vacum pressure is at??? and also the BOV barely hisses.
Old 07-23-2010, 05:56 AM   #7
97nismo
97nismo's Avatar
Trader Rating: (53)
97nismo is an unknown quantity at this point
Feedback Score: 53 reviews
exhaust leak???
97nismo is offline   Reply With Quote
Old 07-23-2010, 10:49 AM   #8
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
loose intercooler pipe
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 07-23-2010, 11:55 AM   #9
spools420a
spools420a's Avatar
spools420a is a well-known jackass
I'll sell you my home boost leak tester for $20,I gotta make somthing off it =]
spools420a is offline   Reply With Quote
Old 07-28-2010, 02:40 PM   #10
volkrps13
volkrps13 is an unknown quantity at this point
could be a major exhaust leak at the turbo/mani or a bad boost leak somewhere in the fmic system
volkrps13 is offline   Reply With Quote
Old 07-28-2010, 03:42 PM   #11
Sileighty_85
turbo seized?
Pull off the turbo intake and see if the turbine wheel spins freely
後輪駆動車1番
1986 SR86 - 200ish
Old 07-28-2010, 03:56 PM   #12
TurboStrong
TurboStrong's Avatar
TurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really nice
check to see if ur actuator arm is loose?
that little ring comes off ever so often and the arm comes off
TurboStrong is offline   Reply With Quote
