Old 07-21-2010, 04:03 PM   #1
shinobis13hb
shinobis13hb's Avatar
shinobis13hb is an unknown quantity at this point
passenger side headlight problem..
well,
yesterday morning i was cleaning up some wiring next to the battery just tucking it to the side.. i had to unplug my HID ballest
well the problem is now the passenger side light doesnt work anymore
things i checked::
the passengerside is getting 0.001V the driver is getting almost 10V
checked all fuses and relays they all are good.
now on the driver side where there are 2 relays for you headlight when i plug the relay that controls the passenger side nothing happens but when i plug in the driver the DRIVER HID will work.
:note:I DID NOT UNPLUG ANYTHING EALSE BUT THE BALLEST
checked all connects all are solid
shinobis13hb is offline   Reply With Quote
Old 07-21-2010, 06:39 PM   #2
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
so what is it that doesnt work... light wont turn on or it wont pop up?
zylvia213 is offline   Reply With Quote
Old 07-21-2010, 08:23 PM   #3
shinobis13hb
no power going to the passenger headlight meaning the light doesn't turn on
Old 07-22-2010, 11:12 AM   #4
shinobis13hb
anyone? ,,,,,,,,,,,,,,,
Old 07-22-2010, 08:57 PM   #5
cotbu
cotbu's Avatar
Assuming you wired your own HID's and it's an s13....try swaping ballast so we can rule out a dead ballast! then check to see if your ballast are wired in series, parallel or separate power and or ground etc. you may have found the problem by now. but let us know what u find. also swap fuses for l&R
Old 07-27-2010, 02:45 PM   #6
shinobis13hb
well i had it done at a shop, just because i was gettin other stuff done aswell.
everything tested good before i "fixed" the problem. it turned out to be ust some rust and stuff on one of the terminal crimps the guy used. thanks again guys.
