Old 07-26-2010, 02:51 PM   #1
shinobis13hb
shinobis13hb's Avatar
shinobis13hb is an unknown quantity at this point
dizzy jumping after put on TDC KADE
well i put my car on TDC and put the dizzy on CYL 1 and go to crank it wont start... i take off the cap and see it has jumped it has done a 180 degree turn... can anyone explain why..? maybe i am doin something wrong??.
p.s. car was running perfect before jsut wanted to see if it was off.. and it was.
shinobis13hb is offline   Reply With Quote
Old 07-26-2010, 05:24 PM   #2
Slip&Sliden 240
Slip&Sliden 240's Avatar
Slip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfection
First of it is a distributor NOT a dizzy, this is not Honda-Tech.
It did not jump, it can not jump 180* from where it was installed. You most likely set it to TDC on the exhaust stroke, not the compression stroke.
Set it to TDC, then remove the oil fill cap and look at the cam lobe for cylinder 1. Make sure it is pointing out or away from the center of the engine. Install the distributor pointing towards cylinder 1 post on the cap. Start car and set timing with a light.
Slip&Sliden 240 is offline   Reply With Quote
Old 07-26-2010, 07:14 PM   #3
shinobis13hb
thanks. sorry never been on Honda tech never will just slang i picked up from my dad. ill try that thanks again.
