Old 07-26-2010, 09:57 PM   #1
jinesz32
jinesz32's Avatar
jinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to behold
Send a message via AIM to jinesz32
Ecu problems ?
I'm having issues with my car.
I was driving it today and All of a sudden the gas doesn't work and my rpm starts jumping like crazy and the car just turns off. I pulled the trim off where the ecu is and I see smoke coming out very very little. I'm guessing the ecu is fried.
I got another ecu but I don't know how to set the little knob behind the ecu . I plugged the old ecu in and the light is red. I don't know what any of this means . If anyone could explain to me how to set the knob clockwise / counter clockwise etc and why the light is red on my old ecu I'd appreciate it.
Thank you .
-JIn
jinesz32 is offline   Reply With Quote
Old 07-26-2010, 10:01 PM   #2
jinesz32
jinesz32's Avatar
The new ecu I got cranks but won't start .
Car is a 95 s14 ka.
My fried ecu is 3D
The new one I got from a friend is WN
Old 07-26-2010, 10:17 PM   #3
Homer_Simpson
Homer_Simpson's Avatar
Homer_Simpson is on the path to ruinHomer_Simpson is on the path to ruinHomer_Simpson is on the path to ruin
If you fried your original ECU then I would suggest that you figure out the reason why your ECU get fried before you plug in another one.
Homer_Simpson is offline   Reply With Quote
Old 07-26-2010, 10:28 PM   #4
jinesz32
jinesz32's Avatar
I think one of the wires ground out somewhere previous owner had safc and cut the wires . I plugged them in and the new one is fine didn't fry . It cranks just doesn't start.
Old 07-26-2010, 10:38 PM   #5
Homer_Simpson
Pop the lid off your new ECU and if anything is roasted.
Old 07-26-2010, 10:41 PM   #6
jinesz32
jinesz32's Avatar
The old ecu smells like something is burned in there . Ill pop it off and check.
Old 07-26-2010, 11:28 PM   #7
Homer_Simpson
Check both.
Old 07-27-2010, 02:13 AM   #8
jinesz32
jinesz32's Avatar
cool i just left my car there at the shopping center for the night gonna open it up tomorrow and check all the wiring.
thanks for the inputs, i appreciate it.
i was doing some research and found this thread.
http://zilvia.net/f/tech-talk/68145-...noise-x_x.html
my ecu did make noise, i'm still doing research and hopefully i can figure it out, the light on the ecu is red, the cel light is on and everything, i just don't know why it won't start, i'm gonna look inside the engine bay and see if any wires got chewed up.
it was probably a bad ground that fried, i'll check it out tomorrow, if anyone has any advice on what i should do id appreciate it.
thank you!
Old 07-27-2010, 02:54 PM   #9
jinesz32
jinesz32's Avatar
Just went to my car right now.
After doing hours of research last night.
I began I diagnose.
I pop open the fuse box under the hood.
Read something about egi fuse popped it off and it was blown. Replaced it and it started up perfect.
Thanks again for input.
Much appreciated.
