![]() Join Date: Dec 2009
could bad gas cause this?
The story is I bought a sr20det 240 coupe and its been sitting while I buy more parts for it,The setup is pretty much stock ie,.
redtop sr walbro 255lph greddy fmic electric fan hks downpipe little buddy club battery other then that its stock I check the plugs and all have the white tips,The car runs just fine but the gas is almost 4 months old,Also the gap was at 0.40 which was a huge gap which should be around 0.28,The cars been running 7 psi boost since I bought it and I have no wideband to monitor afr at the moment,I know the white usually meens heat/lean but I'm wondering if old gas could play a roll in this?Timing is stock still havent checked fuel pressure but I'll do it tomarrow.Everything seems good but the plugs make me worried. The plugs are BKR7E,Any input on what I should check next?Could the gap being that far off or bad gas cause this?Also noticed when I wired in the electric fans it seems to steal some of the fuel pumps power so maybe I should rewire the pump or ground it out better,seems like most things running on acc are taking some juice from the pump ![]() ![]() Last edited by spools420a; 07-27-2010 at 01:48 AM.. |
