Old 07-30-2010, 04:44 PM   #1
yellowxhoodie
yellowxhoodie's Avatar
yellowxhoodie is an unknown quantity at this point
AEM TruBoost 52mm Gauge
will come with gauge, solenoid, silver and black bezel, all wiring and hoses.
selling it cheap because this.
one of the wires pulled out of this plug.
and there is no plug for these wires.
i dont feel like sourcing parts and i havent even tried, if you want to e-mail AEM and see what they can send you or do for you, go ahead, i just dont want to deal with it and i dont plan on using this gauge anyways.
here is some background info taken from AEM's website.
WHAT IT DOES
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
WHY YOU WANT ONE
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks."
PRODUCT FEATURES
No external interface required for programming!
Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings
Quick connect technology eases the installation process
Two user selectable boost settings with peak boost memory
Scramble boost setting allows user to momentarily change boost levels
User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost
User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display
One (1) low-side output included for warning lights
more info and a video available here.
AEM TRU-BOOST Gauge / Boost Controller - Monitor and Control Boost 30-4350
im selling this for $150 Shipped!!!
yellowxhoodie is offline
Old 07-30-2010, 04:54 PM   #2
Jaliscano
Jaliscano is an unknown quantity at this point
Where is the boost controller? I see the gauge and soleniod.
Jaliscano is offline
Old 07-30-2010, 05:21 PM   #3
yellowxhoodie
WHAT IT DOES
Old 08-09-2010, 09:15 PM   #4
yellowxhoodie
bump
msglngth
Old 08-14-2010, 10:16 AM   #5
yellowxhoodie
bump.
msglngth
