Old 08-01-2003, 04:54 PM   #1
novaguy14
novaguy14 is an unknown quantity at this point
Home Made White Face Guages.
Ok, I am very cheap, and am wantin to see if it is possible to make some home made white face guages.
Actually, the only white face part would be the tachometer, because I have a 1992 240sx SE Coupe 5-speed with the HUD.
But, If I found nice clean shot of someones white face tachometer,
took some thick photo paper, printed the tachometer picture onto it cut it out, and then used black sharpie to color the back side of the numbers so that light can not go through, would it work??
If someone can post a clean and close up shot of their tachometer that when printed would be the same size as a real life one, I will cut it out and try I and report back to you if it worked or not.
If you would like to e-mail me pics, send them to [email protected]
Thanks.
1991 Mustang LX
13 lb. Paxton Novi 2000 supercharger, 80 mm MAF, AFM Power Pipe, 70mm TB, Stage II Cobra intake, Stage II TFS TW heads, 1.6 rockers, F303, Keith Craft 306 , DSS main support, MSD 6A ignition, MSD coil, JMS Chip, FRPP wires, Aeromotive fuel system with 42lb. injectors, BBK long tubes, 3550 w/Stage II clutch, Pro 5.0 shifter, 3.73's, Cobra R's, Nitto Drag Radials 611hp @Crank 521 rwhp, 472 rwtq
FOR SALE:
1992 240sx SE Coupe 5-speed $3650 O.B.O.
novaguy14 is offline   Reply With Quote
