Old 08-02-2003, 07:48 PM   #1
Tictakman
Tictakman is an unknown quantity at this point
massive turbo help needed!
Well this is how it went down...
t3 turbo
35mm tial wastegate w 8lbs spring
safc II with -27 across the map- throttle low is 0 throttle high is 50.
370cc injectors
the start up was fine, no stumbling at all. ran it down the road at about 1/4 throttle turned around drove down my street again(1/4 throttle) once again i turned around and gave it about 3/4 gas and let off completely. she stalled, no stumbling or anything just a flat out stall after i let off the gas. after that it wouldnt fire at all.
my buddy out side of the car said he saw a good amount of blue smoke(too rich?).
the engine turns over fine just doesnt seem to fire.
ive checked the spark on the spark plugs- good
checked the injectors- seem to be fine
turned over engine with just stock piping and had great vacuum.
i think im too rich, anyone else?
any help would be awesome!
Zak
Tictakman is offline   Reply With Quote
Old 08-02-2003, 07:59 PM   #2
rps13kid
rps13kid's Avatar
rps13kid is a well-known jackass
Send a message via AIM to rps13kid Send a message via MSN to rps13kid Send a message via Yahoo to rps13kid
blue smoke is not rich that is oil black smoke is rich
rps13kid is offline   Reply With Quote
Old 08-03-2003, 07:51 AM   #3
Tictakman
well i checked my oil level and it looked like it wsa the same. ill do some more testing today.
Zak
Old 08-03-2003, 10:33 AM   #4
PAnut240
PAnut240 is an unknown quantity at this point
Send a message via AIM to PAnut240 Send a message via Yahoo to PAnut240
Hey, what did your spark pluggs look like when you pulled them out. And was the engine running before you put on the SAFC or is it all new. I'm just trying to get a mental picture of everything.
Jim
'89 Fastback  SR20det; Greddy Profec B II boost controller. HKS 262 CAMS. Greddy Radiator,pulleys,oilfilter relocation kit,boost gauge, rockerarm stoppers,intake manifold. Nismo Fuel Press Reg. Ferra duel Valvesprings, ti retainers. East Bear headlight conversion. Type X tail lights. Tien Suspension, Tanabe race exhaust.  GT 16" rims, Walbro high Pressure fuel Pump,  7pt rollcage. HKS BOV. Mandril Exhaust Man. GTR FMIC. BeeR Valve cover. JE Pistons and Eagle Rods.
PAnut240 is offline   Reply With Quote
Old 08-03-2003, 01:06 PM   #5
Tictakman
the spark plugs looked ok. they had a little gas on them. i had the safc on for a week without any other mods, ran fine. then i put on the larger injectors and drove that for a day, higher idle...then later that day i installed the turbo.
Zak
Old 08-03-2003, 03:45 PM   #6
turboex
turboex is an unknown quantity at this point
Mine did the same thing, come to find out I blew of a intercooler pipe, car would not start for hours untill i found the leak damn maf's
1992 240sx SE
s13 silvia frontend conversion
SR20DET, custom top mount turbo manifold, Precision SC61 turbo, blitz bov, HKS intercooler, Tial 38mm wastegate, tenzo-r shu-4's, ton of other shit. with clean new paint!
turboex is offline   Reply With Quote
Old 08-03-2003, 10:03 PM   #7
RacNgi
RacNgi is an unknown quantity at this point
do you have a BOV on your set up? and if you do is it blowing out into the engine bay? Cus if it is thats your problem with the stalling. you need to have bov valve blow the air back into the pipes before the airsensor
RacNgi is offline   Reply With Quote
Old 08-04-2003, 02:54 PM   #8
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Could the plugs be gapped incorrectly?
-m
mbmbmb23 is offline   Reply With Quote
Old 08-04-2003, 02:57 PM   #9
Tictakman
well, i took it to nissan and had my buddy work on it and he did a compression test and has concluded that it is the head gasket. so ill be replacing that this week. does anyone know where i can get a metal one for a ka24de?
Zak
Old 08-04-2003, 03:31 PM   #10
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
you are kinda right...
If you are running a open-atmosphere BOV you have to make sure th BOV is closed at idle or else you will get the stumble. If you vented the air in before the air sensor the car would run horribly rich between shifts. The air has to be vented in after the air sensor.
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 08-05-2003, 10:25 AM   #11
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
y do u have to recirculate the BOV??
would u have ot do this even if u have the BOV closed at idle like u said?
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 08-05-2003, 11:01 AM   #12
RedSuns
RedSuns's Avatar
you don't "HAVE" to recirculate the BOV but by doing this it will prevent the engine from running rich between shifts.
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
Old 08-05-2003, 01:52 PM   #13
Muzzy
Muzzy's Avatar
ah ha ok..but it will run rich for that split second??
lemme have a dollar
Old 08-05-2003, 03:58 PM   #14
RedSuns
RedSuns's Avatar
yup
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
Old 08-05-2003, 04:33 PM   #15
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
www.backyardproductions.com makes a metal HG for the KA24DE...
even if he had the atmospheric BOV, the SAFC II will regulate that with the right tuning...
after the HG i suggest dishing out 100 bux for the Safc dyno tune..
EDIT: hhmm website doesnt work... try this info:
Backyard Productions
468 Northeast 191st Street, Miami, FL 33179
(305) 249-4979
s13silady is offline   Reply With Quote
Old 08-05-2003, 07:21 PM   #16
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
Wow, thats got to be the shortest lived KA turbo EVER
DuffMan is offline   Reply With Quote
Old 08-05-2003, 09:16 PM   #17
Tictakman
ya tell me about it duff.
i didnt have a recirculating bov it was atmospherical.
i think i know what went wrong. i had the pressure line from the valve cover put into the intake( like the stock set up). i think it created too much pressure for something in there and it messed up the gasket. ideas?
i took off the head today and im gonna have a buddy from nissan come over and tell me what he thinks. the gasket looks ok to me but i dont know what to look for.
i have pics for anyone that would like me to send them to ya. just let me know. input on what might have happened would be great. i also have pics of the piston heads and gasket etc.
Zak
