Old 08-02-2003, 11:23 PM   #1
1121S13
1121S13 has a spectacular aura about1121S13 has a spectacular aura about1121S13 has a spectacular aura about1121S13 has a spectacular aura about1121S13 has a spectacular aura about1121S13 has a spectacular aura about
Question SR20DET clutch pressure questions!
I've searched but not too much info on pressure on the pedal for each clutch..
I was looking at spec,centerforce, and ACT.
Its for my stock 89 redtopSR..
i would like to know what would be the one with very minimal pedal pressure. I do alot of traffic driving.
The stock pedal i have now is so much more stiffer then old my KA one..Even if its a clutch for SR.. Iam thinking its tooo stiff...maybe a bad clutch..
would like to hear ppl's opinions about the pedal pressure..
thx..
1121S13 is offline   Reply With Quote
Old 08-03-2003, 12:55 AM   #2
1121S13
anyone?
Old 08-03-2003, 02:30 AM   #3
FRpilot
FRpilot's Avatar
i have a spec stage 3 clutch and the pressure feels liek stock so thats good.
im not sure if its like that b/c i have a stainless steel line also but its pretty light as far as pressure is.
actually, i sure hope i broke in my clutch correctly b/c i installed my short shifter while i was under my car. i know that you're suppose to ease the clutch in so you have soft clutch engagemtn and drive under 3000 rpm, but its kinda tough w/ a short shifter cuz you basically speed shift w/ it.
FRpilot is offline   Reply With Quote
Old 08-03-2003, 03:07 AM   #4
1121S13
would spec2 be lighter pressure on pedal?
does your pedal feel like stock KA? or just slight heavier?
Old 08-03-2003, 10:16 AM   #5
1121S13
iam pinned to my sit.. and stress on my back just to push the clutch in..
Old 08-03-2003, 10:43 AM   #6
mrmephistopheles
mrmephistopheles's Avatar
kearn about clutch setups and how to reduce pedal effort,,, or just trade motors with me... my clutch is feather soft!
Old 08-03-2003, 01:08 PM   #7
1121S13
i already have a KA.
thx for tip
Old 08-03-2003, 01:11 PM   #8
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
With a hydraulic clutch, most setups are going to be pretty soft. A lot of the pressure comes from a spring on the pedal itself. Obviously there's pressure coming from the clutch as well, but it's not the same as a cable actuated system.
Also, as far as breaking in your clutch, a short-shifter shouldn't make any difference at all. It's the way you use the clutch that matters, not the way you shift. As long as you keep it under 4000RPM and don't go to full throttle you should be fine.
Learn everything you can, while you still have the chance.
transient is offline   Reply With Quote
Old 08-04-2003, 12:54 AM   #9
1121S13
but not to a point where i need to stress my back to clutch in.
shouldnt it be just a bit harder then a normal KA clutch?
Old 08-04-2003, 12:57 AM   #10
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
CEnterforce dual friction for 89 maxima is very close to stock feel I was told.
I myself am using a stage-1 act clutch kit. I like it a lot and it's not that stiff..
-> HaLo
Race Car: '98 E36 BMW M3
Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
