Rubbing/almost grinding sound when going in reverse
What do you guys think this is my diff or maybe my brakes (not likely) What should I do? It only happens when I go in reverse no other time.
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
its most likely your rear brake pads
probably isntalled INCORRECTLY check them and im sure you'll find that is your problem. be prepared to buy new pads as well. |
Check to make sure something isn't rubbing. . . part of my engine's underside splash guard broke apart and was dragging on the ground, particularly noticeable in reverse.
Rowsdower saves us and saves all the world! |
#5 |
I get that sound too..does anyone read their owners manual?? It says that sound is normal from time to time..the brakes self-adjusting or something
Who the hell needs a sig anyhow |
#6 |
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
if its the same sound I'm having when i go in reverse, its def not normal. When I got my car teched for a drift event I was told it was probably the bearing (hub bearing?) Might wanna check it out.
